TCS button - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #11 of 18 (permalink) Old 08-15-2003, 09:58 AM
Reading Topic: TCS button
all you need is a relay.. :)
the TCS switch is a momenatary switch . i bet it is grounded.. but hell there is only 1 way to tell .. :)
you will need just a regular relay for like alarms and stuff..
well you take pins 30 and the side one 85 i think .. dam it has been a while :) and ground that .. then you take the other side one .. i do belive 86 and hook that up to the starter wire " so it gets a momantary click when you hit the starter, then you take 87 the top pin and you connect that to the TCS switch .. i will look into this further .. i dont want to do it to my car but .. but hea i know a lot about Electronics
Chris
SQMazda 6 is offline
post #12 of 18 (permalink) Old 08-15-2003, 06:34 PM Thread Starter
-I appreciate your thoughts everyone. I was under the impression that more driver's of the 6 prefered the TCS off on a dry day. I have a 5sp 6s and it is definately easier to execute a smooth quick start with the TCS off. Besides, it seems unnecessary to use a Traction Control System on dry roads anyway. So, I just don't like having to remember to turn it off everytime I start the car. I would definately not go through the trouble or money to have the ECU flashed just for that. But, I think I could handle installing a relay with a little instruction if a relay would in fact do the trick. SQMazda6 and all others- Any information you could provide would be truly appreciated. Thanx
steel 6s is offline
post #13 of 18 (permalink) Old 08-15-2003, 08:36 PM
Gruss's Avatar
Send a message via AIM to Gruss Send a message via Yahoo to Gruss
I've noticed no difference at all with it on or off while driving (manual tranny) so havent thought much about it, might need to have the ecu programmed to have OFF as the default
'03 Mazda6 S
'03 Explorer
'97 VFR
Gruss is offline
post #14 of 18 (permalink) Old 08-15-2003, 08:43 PM
I believe the tcs button is a "press down - on, let up - off" button, therefore, you switch the wires, they'll do the same thing regardless...correct me if I'm wrong, cause I won't have my new 6 'til tomorrow...I can't remember.
2005 Black Cadillac CTS 3.6L
tucker is offline
post #15 of 18 (permalink) Old 08-16-2003, 04:34 PM
Steve 6er's Avatar
No, it's a single mode switch. It just sends a pulse to the computer telling that you hit the switch. It's the computer that keeps track of the on/off mode.
Steve 6er is offline
post #16 of 18 (permalink) Old 08-16-2003, 04:35 PM
Driver6's Avatar
The problem on European models is that if you turn off TCS you switch off DSC as well and this might save your butt on occasion. You know that when you least expect it something might happen to you and in that moment you wish not to have turned off TCS/DSC...
I want to die in my sleep just like my grandfather did and not screaming and yelling like his front seat passenger.
Driver6 is offline
post #17 of 18 (permalink) Old 08-18-2003, 04:54 PM
Steve 6er's Avatar
Reading Topic: Reading Topic: TCS b
Yeah, I never turn off anything. Couldn't figure out why I'd do anything of that kind.
post #18 of 18 (permalink) Old 08-18-2003, 05:05 PM
dBo
Replying to Topic 'TCS button'
QUOTE
Originally posted by Gruss
* * * * * * I've noticed no difference at all with it on or off while driving (manual tranny) *so havent thought much about it, might need to have the ecu programmed to have OFF as the default[/b]
I decided to try and see if there were any difference when TCS was on or off.
I'm not sure if the placebo effect deal is going on or not .. but it seems that the car is much smoother/easier to drive when its off. I have a manual 5 spd tranny S and its noticeably smoother on take offs and on shifts.
anyone else experience this also?
dBo is offline
