cell phone plug always on - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 17 (permalink) Old 05-29-2003, 07:01 AM Thread Starter
mr-patate's Avatar
anybody remove the center console the wire the cell phone plug to the continius 12 volts.
i like to use it to gharge my phone at the job or to plug a cooler on during summer, but the plug only work when key's are on!:(
mr-patate is offline
post #2 of 17 (permalink) Old 05-29-2003, 02:37 PM
atom44wat's Avatar
Reading Topic: cell phone plug always on
just use the one next to the ash tray
atom44wat is offline
post #3 of 17 (permalink) Old 05-29-2003, 08:38 PM Thread Starter
mr-patate's Avatar
dosent work as well, both of them work whit accessories. i already try this out.
post #4 of 17 (permalink) Old 05-30-2003, 02:15 AM
atom44wat's Avatar
hmmm i dunno then
post #5 of 17 (permalink) Old 05-31-2003, 11:39 AM
I'd like to know too.
BoDEAN
Michigan MAZDA 6S Owner/Driver
BoDEAN is offline
post #6 of 17 (permalink) Old 06-01-2003, 10:48 AM
kyler13's Avatar
Replying to Topic 'cell phone plug always on'
QUOTE
Originally posted by mr-patate
* * * * * * anybody remove the center console the wire the cell phone plug to the continius 12 volts.
i like to use it to gharge my phone at the job or to plug a cooler on during summer, but the plug only work when key's are on!:([/b]
One sure way is to tap off the continuous 12 volt power to the radio and run through the center console back to the accessory plug you're talking about. Do you have the standard radio or Bose system? Someone on here has the wiring scheme for the base audio package.
kyler13 is offline
post #7 of 17 (permalink) Old 06-01-2003, 02:24 PM
I doubt if the 12v line to keep the radio memory alive is of sufficient size to carry the potential (no pun intended) amperage that these accessory points may be called upon to supply.
The safest way would be to run a seperate hot wire from the fuse box (look for a fuse location that is otherwise unused, such as moonroof or power seat or an extra slot if there is one). I would run at least as heavy a gauge as is already used.
pgmr is offline
post #8 of 17 (permalink) Old 06-01-2003, 08:37 PM
kyler13's Avatar
I doubt a cell phone charger drawing 500mA is going to overload the circuit.
kyler13 is offline
post #9 of 17 (permalink) Old 06-03-2003, 12:50 PM
mazda6guy's Avatar
Quoted: 70 Post(s)
I like that it turns off. I'm scared my battery will drain.
Current Mazda
2018 Mazda6 Signature
Machine Gray Metallic
Previous Mazdas
2014.5 Mazda6 GT
Meteor Gray Mica
2008 Mazdaspeed3 GT
Sunlight Silver
2006 Mazdaspeed6 GT
Velocity Red
2003 Mazda6 Sport V6
Glacier Silver
1996 Mazda MX-6 V6
Emerald Green
mazda6guy is offline
post #10 of 17 (permalink) Old 06-03-2003, 02:06 PM
QUOTE
* * * * * * i like to use it to gharge my phone at the job or to plug a cooler on during summer, but the plug only work when key's are on!:([/b]
No, but a cooler drawing several amps might. Who knows what else he might want to plug in someday: Power inverter, big spotlight, air compressor, etc. Using an under-gauge supply line is asking for a fire.
pgmr is offline
