Keyless Remote Entry - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 72 (permalink) Old 03-06-2003, 10:33 AM Thread Starter
Hey, does anybody know how to program a keyless entry remote to the car? Also, does anyone know if you can have more than two (2) remotes keyed to a car? I want to buy a third keyless remote.
Thanks
Indy MPS6 is offline
post #2 of 72 (permalink) Old 03-06-2003, 10:38 AM
Steve 6er's Avatar
Reading Topic: Keyless Remote Entry
My dealer told me you could have three but no more than three remotes.
But you can't programme them yourself. The dealer has to do that (they use a special programming tool). They also need one of your present remotes to do that.
Steve 6er is offline
post #3 of 72 (permalink) Old 03-06-2003, 12:49 PM Thread Starter
Thanks. I was hoping to be able to do it myself and save the $. I know with my Probe there was a way to do it with opening the trunk and putting the key in the ignition, blah, blah, and I was hoping it was the same/similar with the 6.
post #4 of 72 (permalink) Old 03-06-2003, 04:24 PM
Steve 6er's Avatar
NAFAIK, nope.
post #5 of 72 (permalink) Old 05-28-2003, 04:40 PM
Replying to Topic 'Keyless Remote Entry'
I figured out how to do it. This works for the keyless entry but not for the immobilizer key. I haven't figured that out....YET!
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the drivers door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the drivers door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Boston6 is offline
post #6 of 72 (permalink) Old 05-28-2003, 04:44 PM
Absolut's Avatar
Send a message via AIM to Absolut Send a message via MSN to Absolut
Wow.. Great post. How did you figure this one out?
Storm Reports Map:
Absolut is offline
post #7 of 72 (permalink) Old 05-28-2003, 05:29 PM
Steve 6er's Avatar
Me wonders too...
I guess you had access to the technical manual? :)
post #8 of 72 (permalink) Old 05-28-2003, 07:08 PM Thread Starter
Thanks!!!!!!!
post #9 of 72 (permalink) Old 05-28-2003, 08:54 PM
Send a message via AIM to stew560
i can see it now...it was all B.S. and a bunch of guys are outside opening and closing their doors witha printout of this post in their hand.... :D
stew560 is offline
post #10 of 72 (permalink) Old 05-29-2003, 05:12 AM
haha. its like a cheat code.
open your driver door 34 times, then take two steps to the right. You will gain 10HP everytime you do this. After doing this, bang your head onto a wall.
miso is offline
