Light Change out... - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 21 (permalink) Old 02-14-2003, 11:45 PM Thread Starter
Simple_Man's Avatar
Light Change out...
Here are the best pics I could provide ... Sry :sarc :sarc
Main Driving Light are CATZ Galaxy Whites H1's:
Parking/City Lights are Silver bulbs:
White LED's on license plate lights:
I really like the look and the pictures really can't do them justice....
Much better than OEM!:D
<div align="center">
[b]
w/remote start<span style="color:#000000">.
Simple_Man is offline
post #2 of 21 (permalink) Old 02-15-2003, 01:24 AM
Replying to Topic 'Light Change out...'
the h1 lighting looks good! you have made my decision to switch bulbs!
chaochi is offline
post #3 of 21 (permalink) Old 02-15-2003, 02:17 PM
Send a message via MSN to masteryang
How did you changed out the bulb?? it seems impossible to change out the bulb without taking off the bumper, i have a Mazda6 s and i guess the engine and the intake took all the space under the hood...it's so hard to reach to the back of the headlight assemblies to change the bulb...let me know how you changed it, did you have to take off some parts to change it?
Unichip
AEM Short Air Intake
Hawks HPS brake pad
Tokico HP Series Shocks
xtec 5000 HID light system
MagnaFlow Exhaust System
Progress Sway Bar (24mm)
Eibach Lowering Spring Pro Series
Enkei RPM-03 18x7 +48mm Wheel
masteryang is offline
post #4 of 21 (permalink) Old 02-15-2003, 03:29 PM Thread Starter
Simple_Man's Avatar
QUOTE
Originally posted by masteryang
* * * * * * How did you changed out the bulb?? it seems impossible to change out the bulb without taking off the bumper, i have a Mazda6 s and i guess the engine and the intake took all the space under the hood...it's so hard to reach to the back of the headlight assemblies to change the bulb...let me know how you changed it, did you have to take off some parts to change it? *[/b]
Not hard at all... Start with passenger side first... There is a black cover sealing the rear of the headlight housing. On top is the fastening latch. Once off, you can reach inside and feel the H1 bulbs and harness... Easy, unplug and install. Now the Drivers side and Parking lights were tough and it helps to have 2 ppl and one with small hands :)
One person pushes back on air filter box while other reaches inside to change bulbs... Just a reminder, Parking lights pull straight out with some wiggling and effort, they DO NOT twist or turn... Trust me... It's kinda hard to explain, but you dont have to remove ANYTHING, and there's no way too get really good photos...
[b]
post #5 of 21 (permalink) Old 02-15-2003, 06:35 PM
NY Mazda6's Avatar
Reading Topic: Light Change out...
ok...so it's plug n' play then right? No new fuses or anything like that right? Doesn't Catz also have replacement H-4's ---> the car would then have...as Catz says...a "poor man's" HID (white-ish and blue-ish tint)...anyone know...
NY Mazda6 is offline
post #6 of 21 (permalink) Old 02-15-2003, 07:39 PM Thread Starter
Simple_Man's Avatar
QUOTE
Originally posted by NY Mazda6
* * * * * * ok...so it's plug n' play then right? No new fuses or anything like that right? Doesn't Catz also have replacement H-4's *---> the car would then have...as Catz says...a "poor man's" HID (white-ish and blue-ish tint)...anyone know...[/b]
Yes, that's what Im running... $65.00 1 year guarantee on bulbs They have ALL models of bulbs.
[b]
post #7 of 21 (permalink) Old 02-15-2003, 08:10 PM
Hi Simple_Man , I have a V6 Engine, and to me it seems like the passenger side is much harder to change than the driver side. I just order a PIAA Plasma Spark Blue H1 (7500K HID) light bulb straight from Japan. and I got them today. I can't wait to put it on it!! ^_^
Unichip
Hawks HPS brake pad
post #8 of 21 (permalink) Old 02-16-2003, 12:19 AM Thread Starter
Simple_Man's Avatar
Well, you got me there.... I have not even seen the V6 engine compartment... I can only speak on behalf of the 4 cyl. Sry, you in uncharted territory! Those should look real nice... Their about $100 aren't they?
[b]
post #9 of 21 (permalink) Old 02-16-2003, 01:11 AM
Yes, I got it on Ebay and with shipping it cost about 96 dollars. by the way, here's a picture of the V6 engine of M6, you can see on the passenger side there's a radiator fluid container which makes it impossible to change the bulb :(
http://www.czech1.net/mazda6/mazda6_19.jpg
Unichip
Hawks HPS brake pad
post #10 of 21 (permalink) Old 02-16-2003, 08:34 AM Thread Starter
Simple_Man's Avatar
DEAR GOD! :( Your not kiddin.... Im glad to have my 2.3L. :) Good luck brother...
[b]
