TCS? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 7 (permalink) Old 01-24-2003, 01:48 AM Thread Starter
TCS?
Is TCS the system where the computer engages your brakes if it doesn't detect traction?
Omega is offline
post #2 of 7 (permalink) Old 01-24-2003, 02:23 AM
Reading Topic: TCS?
Actually thats brakeforce distribution... TCS either limits ignition (most common from the factory) or fuel injector duty cycle (high-performance aftermarket types) in order to curb engine output. Brakeforce distribution clamps down on the corners of the car while the power is still being piled on and is used more to control the attitude of the car rather than overall traction.
-Alt
Altersys is offline
post #3 of 7 (permalink) Old 01-24-2003, 11:54 AM
Replying to Topic 'TCS?'
Actually, I believe the TCS does use ABS to prevent wheelspin. At least I am pretty sure it does in the Mustang, and I'd guess all TCS systems work on similar basis.
CzechMate is offline
post #4 of 7 (permalink) Old 01-24-2003, 01:07 PM
Absolut's Avatar
Send a message via AIM to Absolut Send a message via MSN to Absolut
Here's how most TCS Systems work...
Traction Control Systems have an electronic sensor on each of the four wheels to determine when a wheel is spinning. When a car begins to slide, or even a wheel, the sensors transmit a signal to the ECU, which then determines how to regulate the brake pressure. If the wheel speed is greater than the vehicle speed, the ECU applies the brakes to that wheel, engaging the traction control system and transferring the torque to the wheels with traction. If the ECU senses the brake is locked, it engages the ABS.
Storm Reports Map:
Absolut is offline
post #5 of 7 (permalink) Old 01-25-2003, 01:12 AM
Reading Topic: TCS?
Hmmm... it was my understanding that EBD is what you just described... but I could definitely be mistaken
IMO the best TCS's use fuel injection control, ie check out http://www.racelogic.co.uk
-Alt
Altersys is offline
post #6 of 7 (permalink) Old 01-25-2003, 10:11 PM
Reading Topic: TCS?
I googled 'Traction Control' and this seems to be a pretty good article over at Edmunds.com.
http://www.edmunds.com/ownership/safety/ar...52/article.html
mpulse1 is offline
post #7 of 7 (permalink) Old 01-27-2003, 04:48 PM
Reading Topic: TCS?
Looks like a combination of braking and throttle manipulation. Thanks for the link.
-Alt
Altersys is offline
