Alternator output on the 6s? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 8 (permalink) Old 12-18-2002, 11:06 PM Thread Starter
Anyone know what the alternator is rated for on the 6s (North America)?
Entropism is offline
post #2 of 8 (permalink) Old 12-19-2002, 04:42 PM
Replying to Topic 'Alternator output on the 6s?'
What I can remember, it is 90A for the 6i and 110A for the 6s.
hieppo is offline
post #3 of 8 (permalink) Old 01-08-2003, 09:48 PM Thread Starter
I double checked... It's 100 amps for the 6i, and 120 amps for the 6s.
post #4 of 8 (permalink) Old 11-30-2003, 10:03 PM
Reading Topic: Alternator output on the 6s?
Thanks for this info
White Knight is offline
post #5 of 8 (permalink) Old 11-30-2003, 11:25 PM
84FordMan's Avatar
You sure? Because I have been looking into a higher output alternator option to well power my high input audio system I am planning. Since the V6 was a partial parts bin engine, I assumed the alternator may have been carried over from the current generation/final generation Taurus 3.0L, so I looked up belt routing on Mitchell On Demand and the S engine code 3.0L has the EXACT SAME belt routing! Minus the water pump, which I believe was moved over to the other side of the motor. Yet the A/C compressor, alternator, belt tensioner and crankshaft pulley are all in the SAME spots on the M6 3.0L as they are on the S-engine code 3.0L Taurus.
And to make a long story short, our parts catalog at work says the 2000 S-engine code Taurus has a 130 amp alternator.
So if someone is truely desperate from 10 more amps, I find it highly logical that the alternator was indeed carried over from the Taurus. Also use this info to your advantage in finding higher-output alternators, as I know dealing with alot of aftermarket producers generate the automated "We don't have anything for that vehicle" response when they hear "2003" and "Mazda 6" in the same sentence.
1994 Mazda B3000 SE
Daily driver
84FordMan is offline
post #6 of 8 (permalink) Old 11-30-2003, 11:53 PM
Current
Verify that the battery is fully charged.
Charge if necessary.
Disconnect the negative battery cable.
Connect an ammeter, capable of reading 120 A or above , between generator terminal B and the wiring harness.
Connect the negative battery cable.
Turn off all electrical loads.
Start the engine and increase the engine speed to 2,0002,500 rpm .
Turn the following electrical loads on and verify that the current reading increases.
Headlights
Blower motor
Rear window defroster
If generator terminal B current does not increase, repair or replace the generator if necessary.
NOTE:
Current required for generating power varies with electrical loads applied.
Standard current (Reference)
Measuring conditions:
Room temperature: 20 C {68 F}
Voltage: 13.5 V
Engine hot
Engine speed (rpm) Terminal B current (A)*
L3 AJ
1,000 0*80 0*90
2,000 0*100 0*105
Lower limit of current must be more than 0 A.
FYI
Snap-On is offline
post #7 of 8 (permalink) Old 12-01-2003, 01:37 AM Thread Starter
Better yet.... Look at the main fuse rating at the fusebox. Easiest way to tell what amperage an alternator is putting out.
post #8 of 8 (permalink) Old 12-01-2003, 02:16 AM
atom44wat's Avatar
so what is the final answer?
atom44wat is offline
