Traction Control? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 20 (permalink) Old 08-05-2002, 06:41 PM Thread Starter
Traction Control?
Does anyone know if the Mazda 6 will include or have options for Traction control, & can it be turned on/off?
vlad1966 is offline
post #2 of 20 (permalink) Old 08-06-2002, 02:55 AM
Steve 6er's Avatar
Replying to Topic 'Traction Control?'
Yes. In Sweden it has TCR in all models but the 1.8 version. And it can, as in the 626, be turned off. In fact I learned that the one and only component that is the same in the 6 as in the 626 is the switch for TCR...
You have to check before you buy though if TCR is included or if it is optional on the model you choose.
Steve 6er is offline
post #3 of 20 (permalink) Old 08-06-2002, 04:32 AM
QUOTE
Originally posted by Steve 6er
* * * * * * In Sweden it has TCR in all models but the 1.8 version. *[/b]
In Estonia it has DSC, TCS and BA as an option with 1,8 version (+450$). EBD and ABS are standard in all models, as well as disc brakes on all round (vented in front). I think it should be the same in Sweden.
Sigvard is offline
post #4 of 20 (permalink) Old 08-06-2002, 10:59 AM
There has been some discussion that traction control and stability control may not make it over on the US versions. Frankly that sucks ass. :(
kenoka is offline
post #5 of 20 (permalink) Old 08-06-2002, 04:10 PM
Location: the gap that lies between the fraction of one attosecond and the nextů
As per MazdaUSA's web site, the "S" will have TCS standard, along with ABS/EBD. Both of these are also listed as Package Options on the base.
applejax is offline
post #6 of 20 (permalink) Old 08-14-2002, 04:13 PM
And what about stability control?
kenoka is offline
post #7 of 20 (permalink) Old 08-14-2002, 04:31 PM
Steve 6er's Avatar
QUOTE
Originally posted by kenoka
* * * * * * And what about stability control?[/b]
As far as the specs, it will be optional. On the other hand, I'm quite sure that Mazda USA has not set the different packaging levels yet. For several reasons. One is them being able to analyze the data from sales all over the world...this time you guys are last. Bad for you (and good for us, it's usually the other way around...)
I'm sure there will be packaging levels available where you will have all the goodies standard...
/Steve
post #8 of 20 (permalink) Old 08-14-2002, 05:49 PM
It looks like we only get two trim levels. "I" and "S".
kenoka is offline
post #9 of 20 (permalink) Old 08-14-2002, 07:22 PM
QUOTE
I am thinking (hoping) traction control will go along with stability control; ie. get stability and you get traction.
applejax is offline
post #10 of 20 (permalink) Old 12-12-2002, 04:43 AM
Send a message via AIM to White 6s Send a message via Yahoo to White 6s
i have a us spec 6s. it has traction control which has a button so it can be toggled on/off. as well it does have abs. on the 6s (6 cylinder) both are standard. as for stability control. its not offered.
White 6s is offline
