DIY: 2016 Mazda6 Sub and Amp Install (Non-Bose) - Page 9 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 4Likes
post #81 of 85 (permalink) Old 01-06-2019, 09:43 PM
Quoted: 120 Post(s)
PAC didnt work at all on my 2014, non bose. Had to find another solution
mach1219 is offline
post #82 of 85 (permalink) Old 01-06-2019, 09:55 PM
salasjairo's Avatar
Quoted: 13 Post(s)
Originally Posted by mach1219 View Post
PAC didnt work at all on my 2014, non bose Had to find another solution
For any mazda 6 (2003-2018) with no Bose system (whitout Bose amplifier) should be work!
https://pac-audio.com/search?control...ch_query=Mazda
https://pac-audio.com/catalog/audio-...zda&results=37
salasjairo is offline
post #83 of 85 (permalink) Old 02-03-2019, 12:29 PM
cotydlux's Avatar
Quoted: 7 Post(s)
It worked on my 2014 6 with Bose. I have a thread all about it on here. I took it out when I got rid of that car and I'll be trying it on my new 2018 6 GT with Bose for a sub upgrade. I'll update when I do.
cotydlux is offline
post #84 of 85 (permalink) Old 02-03-2019, 12:58 PM
cotydlux's Avatar
Quoted: 7 Post(s)
Well I just tried and from what I can tell, the old PAC that I used in my 2014 6 with Bose does not work on this 2018 with Bose. I've taken a couple of pics to show the location under the glovebox and also the two plugs compared side by side. On my 2014, I removed the radio and inserted the PAC behind the connection back there. On this 2018, you can also take the tablet out and put a POC back ther but it's the same plug as by the Bose box so this ADD-MAZ2 PAC will not work on my car. I also have a picture of the plugs under the pasngr seat where the Bose amp is and it doesn't work there either.
Looks like we will have to tap into the wires to add an LOC for now. I have emailed PAC to see if they have a new model.
ID:	226258   Click image for larger version
ID:	226260   Click image for larger version
ID:	226262   Click image for larger version
cotydlux is offline
The Following User Says Thank You to cotydlux For This Useful Post:
Trippp (02-03-2019)
post #85 of 85 (permalink) Old 02-03-2019, 07:52 PM
Trippp's Avatar
Quoted: 155 Post(s)
Groans: 5
I can confirm this. I got the PAC adapter and a subwoofer a while ago and just today I finally had some time to tackle this. I looked at a number of videos and threads about the install on Bose and non-Bose systems and was ready to do it. Wasn’t sure if it was just me missing something but the 2018s are different... at least the GT Reserve with the Bose system is. The PAC adapter plug isn’t the right size. And, the hardware under the dash/passenger footwell is different.
Bummer.
@cotydlux...Thanks for sharing. Let us know if PAC responds and keep us posted if you figure an alternate way. Maybe we should start a 2018 audio thread.
'18 Machine Gray GT Reserve
Trippp is offline
