DIY: Mazda GJ 6 Independent Fog Light Mod - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 2Likes
post #1 of 22 (permalink) Old 07-27-2015, 10:45 AM Thread Starter
chutoyy's Avatar
Quoted: 156 Post(s)
iTrader: 3 reviews
So.. ignoring the debate about legality, here's an independent fog light mod. I've done this mod on all of my cars that had fogs and with the new TRS LED Fogs, it's a perfect time to figure this out. It's not as easy as a Honda or Subaru, but has the same concept with an additional relay.
I was doing a trial and error so this DIY isn't fully comprehensive so you will need to use some problem solving and thinking. As always, I take NO responsibility for any damage, harm, injury, destruction, etc... for your actions.
Parts:
Mini Add-A-Fuse
12v Automotive Relay
- I'm using
- This also works
Extra wire, crimps, soldering iron, etc...
Begin with the removing the control stalk.... then proceed below.
1 - Start Here... maybe without the small relay on the top right.
2 - Pop off clear plastic cover
3 - Exposed. Unplug connector. We're after the brown wire.
4 - Use a pick or a tiny flat head to release the pin from the connector.
5 - You'll be left w/ this.
6 - Take some wire, strip off about 1cm, then insert it into the connector on the brown wire, then drop some solder in there and heat shrink it. (You can also cut the connector off the brown wire and use a butt connector or solder, etc... but I wanted my install reversible)
7 - Put it back together.
8 - Put it back in the car.
9- End result.. something like this.
Name:	FM S (9).jpg
ID:	158185   Click image for larger version
Name:	FM S (8).jpg
ID:	158193   Click image for larger version
Name:	FM S (7).jpg
ID:	158201   Click image for larger version
Name:	FM S (6).jpg
ID:	158209   Click image for larger version
Name:	FM S (5).jpg
Name:	FM S (4).jpg
ID:	158225   Click image for larger version
Name:	FM S (3).jpg
ID:	158233   Click image for larger version
Name:	FM S (2).jpg
ID:	158241   Click image for larger version
Name:	FM S (1).jpg
chutoyy is offline
post #2 of 22 (permalink) Old 07-27-2015, 10:46 AM Thread Starter
chutoyy's Avatar
Quoted: 156 Post(s)
iTrader: 3 reviews
You'll need to use some problem solving and thinking, as well as crimp some wires and such for this step. Again, I'm not liable for any damage, short circuits, fire, bodily harm, etc...
Wiring is based off 2015 Mazda 6 Touring. Sport and/or Grand Touring may be different.
A pretty bad schematic...
This is the relay you want, pull it out.
Use an add-a-fuse in the in-cabin fusebox behind the driver's side kick panel (You may want to buy the low profile ones.)
- The third slot was unused from factory but gave a switched 12v so I used it.
Next step is to run the aux relay power supply wire through the firewall. (There are multiple ways of doing this, but I poked a hole in the rubber grommet and poked it through; if you do this BE EXTREMELY CAREFUL of NOT damaging the bundle of wires inside.) That thick blue wire is for my audio setup... you want to look at the thin blue wire. This was the hardest part of the install.
In Cabin:
Engine bay, battery removed:
I got lazy and didn't want to disassemble the fusebox... but it's up to you if you want to make a clean install and tuck the wire in the factory harness guide. This require loosening/removing battery tray.
Here's the end result of what goes on in the fusebox. Make sure connections are secure and any bare metal is covered as best as possible. If you use the right amount/gauge of wire, you can tuck the relay into the hole and the fuse box will close with no issues.
An idea of what you'll see in cabin. I have additional accessories and crap so there's more wiring floating around.
ID:	158265   Click image for larger version
ID:	158273   Click image for larger version
ID:	158281   Click image for larger version
ID:	158289   Click image for larger version
ID:	158305   Click image for larger version
ID:	158313   Click image for larger version
chutoyy is offline
post #3 of 22 (permalink) Old 07-27-2015, 10:46 AM Thread Starter
chutoyy's Avatar
Quoted: 156 Post(s)
iTrader: 3 reviews
Completed:
OEM Factory Fog Harness:
Fog On - Independent
Parking + Fog
Parking + Low + Fog
Parking + Low + Fog + High
AutoExe!
Yep, all of this to retain the factory fog stalk and ability to use factory harness. It's probably 1000 times easier to run an aux relay w/ an external switch.... but that's no fun.
Name:	FM F (5).jpg
ID:	158137   Click image for larger version
Name:	FM F (4).jpg
ID:	158145   Click image for larger version
Name:	FM F (3).jpg
ID:	158153   Click image for larger version
Name:	FM F (2).jpg
ID:	158161   Click image for larger version
Name:	FM F (1).jpg
Name:	FM F (6).jpg
chutoyy is offline
The Following 2 Users Say Thank You to chutoyy For This Useful Post:
DrFeelGood (05-18-2019), fireandicekarim (03-15-2016)
post #4 of 22 (permalink) Old 07-27-2015, 11:38 AM
Quoted: 47 Post(s)
I did the same think, but had to put an extra switch and run wiring harness to the fog lights. Can you give some more details on the wiring, since your setup is much cleaner. Thx.
aachoo is offline
post #5 of 22 (permalink) Old 07-27-2015, 11:52 AM
biking4jesus's Avatar
Quoted: 106 Post(s)
yea where does the red wire go thru the firewall?
what relay are you using? wiring diagram please?
05 Mazda3 Hatch
biking4jesus is offline
post #6 of 22 (permalink) Old 07-27-2015, 05:50 PM Thread Starter
chutoyy's Avatar
Quoted: 156 Post(s)
iTrader: 3 reviews
Still working on the car... Will get pics up later tonight if I finish putting everything back together.
chutoyy is offline
post #7 of 22 (permalink) Old 07-28-2015, 08:52 AM Thread Starter
chutoyy's Avatar
Quoted: 156 Post(s)
iTrader: 3 reviews
Ok, DIY thread finished. For those that know what they're doing, just look at the crappy schematic pic in post #2 ....
chutoyy is offline
post #8 of 22 (permalink) Old 07-28-2015, 12:27 PM
Quoted: 47 Post(s)
Just for my sanity, is there any reason we can't directly connect the brown stalk wire to 86 connector on the relay in the engine bay. It the purpose of the relay in the cabin to make sure the fog lights turn off when car is turned off?
aachoo is offline
post #9 of 22 (permalink) Old 07-28-2015, 01:13 PM
Quoted: 106 Post(s)
ditto on above comment- on my 05 we only ran one wire on the relay in the engine bay. didnt add another relay. fogs stay on for a minute or two after turning car off.
05 Mazda3 Hatch
post #10 of 22 (permalink) Old 07-28-2015, 03:37 PM Thread Starter
chutoyy's Avatar
Quoted: 156 Post(s)
iTrader: 3 reviews
I did the same thing for my old Civic and Subarus, but they were just basic on/off relay systems.
The fogs on this car are controlled by the Front BCM and the interior relay bypasses that. I also tried connecting the wire from the stalk to the oem relay w/ +12v from the fusebox and it didn't do anything on my car.
chutoyy is offline
aachoo (07-29-2015), Mason Dixon (03-25-2017)
