DIY: Mazda GJ 6 Independent Fog Light Mod - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 2Likes
post #11 of 21 (permalink) Old 03-15-2016, 07:11 AM
Quoted: 7 Post(s)
what leds are you running for the drl and the turn? Did you wire a resistor for the turn signal?
kashimus is offline
post #12 of 21 (permalink) Old 03-16-2016, 03:32 AM Thread Starter
chutoyy's Avatar
Quoted: 155 Post(s)
iTrader: 3 reviews
Uhh.. Some LED module I found on Amazon as the DRL block on my bumper.
And yes, resistors for the turn signal because I'm not a fan of they hyperflash.
chutoyy is offline
post #13 of 21 (permalink) Old 03-16-2016, 03:17 PM
biking4jesus's Avatar
Quoted: 106 Post(s)
thanks for the updates
05 Mazda3 Hatch
biking4jesus is offline
post #14 of 21 (permalink) Old 03-17-2016, 04:24 PM
Quoted: 29 Post(s)
Totally unrelated, but are those the Mazda aluminum pedals or something else?
2014 Mazda6 Sport with 6-speed
- Koni Sport Dampers with H&R Springs
- Morimoto 4500k HIDs
2001 Miata Project (blown engine)
mcbru is offline
post #15 of 21 (permalink) Old 03-18-2016, 05:41 AM Thread Starter
chutoyy's Avatar
Quoted: 155 Post(s)
iTrader: 3 reviews
ahah. err... They were some $10 ebay aluminum pedals (requires drilling); couldn't justify $60 for OEM.
mcbru likes this.
chutoyy is offline
post #16 of 21 (permalink) Old 03-24-2017, 01:01 PM
Zeffer's Avatar
Quoted: 171 Post(s)
Necro'ing this thread after a year, so my apologies, but question for you @chutoyy . Does this let you run the fog lights when the car is off? Is that possible this way, or does it have to be wired differently to do so?
Jacksonville, FL
Zeffer is offline
post #17 of 21 (permalink) Old 03-30-2017, 11:32 PM Thread Starter
chutoyy's Avatar
Quoted: 155 Post(s)
iTrader: 3 reviews
This mod does not, but if you wire it to an unswitched 12v power supply then yes, you can run it whenever.
I used a switched power supply so it doesn't kill my battery if I leave the lights on and exit my car
Zeffer likes this.
chutoyy is offline
post #18 of 21 (permalink) Old 03-31-2017, 12:39 AM
Zeffer's Avatar
Quoted: 171 Post(s)
Sweet. Attempted it last night, but getting the wire through the firewall is a real PITA. Going to give it another swing on Sunday. Thanks for the writeup.
I also peeped your thread on hidplanet - good stuff in there too.
Jacksonville, FL
Zeffer is offline
post #19 of 21 (permalink) Old 03-31-2017, 11:10 AM
toy4x's Avatar
Quoted: 210 Post(s)
I would love to be able to use my led drl's and signature grille... No way to do that now unless car is in drive.
Sent from my SM-G935V using Tapatalk
toy4x is online now
post #20 of 21 (permalink) Old 01-07-2019, 09:26 AM
Quoted: 8 Post(s)
Ok guys good write up now see if you can understand what I’m going to write ok I have some eBay DRL lights that are LED and turn yellow when connected to the signal light wires now what I want to do is just run the hot wire to the fuse box when I turn the car on they will turn on I do want to run a extra in line fuse now do you guys think it will be ok?
Thanks! RJ
Now I’m just sharing this because some member mentioned about having a signature series grill well I bought two LED Tube lights that fit perfect on my 2017 Mazda 6 Touring the light tube will fit from where the chrome starts by the headlights to the center of the license plate so one could make the connection behind the plate and it won’t be seen but the only thing is since my 6 is just the Touring the Tube led will be exposed but when one is in it the carvthe Tube will be well lite even in the day it’s bright maybe brighter than the Grand Touring grill light.
Here’s another one now that I’m here does our 2017 Mazda 6 Touring have a tweeter and if so where is it or is it just the paper cone on the door speaker?
Zoom-Zoom6 is offline
