DIY: DDM-Tuning HID install!!! - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 5Likes
post #11 of 55 (permalink) Old 03-22-2015, 10:53 PM
cibersay's Avatar
Quoted: 248 Post(s)
Don't the H11 HIDs come with return wire on top of the bulb that produces a shadow in the light pattern? I thought you had to use H11B to avoid that?
55W is an overkill, a pair of glaring suns for oncoming traffic, melt your projectors, and wiring harness There is absolutely no place for them in headlights that were designed for halogen bulbs.
Nihilus - I couldn't agree with you more
I also don't understand the madness behind wanting "a nice blue tint" - ever looked straight at real factory HIDs? They are white! They only produce a slight blue hue under an angle. In addition, the higher you go on a kelvin chart, the less light you are actually projecting on the road. In laments terms, the prettier your headlight color looks, the less useful they actually become.
cibersay is offline
post #12 of 55 (permalink) Old 03-23-2015, 09:21 PM
Quoted: 7 Post(s)
Thanks so much for posting this DIY. Just performed this on my touring and it looks awesome. I got the 35w 5000k from ddmtuning.
Install was as easy as it seems. I went in from the top and only thing I removed was the fuse box cover. I must say that my "smaller" Asian hands allowed me to do this without taking anything else off. :-)
Everything was simply plug and play. If the light doesn't light up once connect, try changing the polarity of the bulb harness to the factory harness (flip it around).
Best $40 mod ever! Esp with our preexisting projector headlights.
snoWhite and LeadSled like this.
dangle13 is offline
The Following User Says Thank You to dangle13 For This Useful Post:
snoWhite (03-24-2015)
post #13 of 55 (permalink) Old 03-25-2015, 12:03 AM Thread Starter
snoWhite's Avatar
Quoted: 23 Post(s)
@kodiak
Yes, buy the H11. I got 35W and 5000K, but the 4300K should give a clean white color. Mine are blueish but that's OK cuz it matches the license plate lights. They also match the interior domes and map and courtesy lights... And the trunk light. Swapped them all. And the glove light. So, it depends what ur going for. Looks really sharp at night and the bump in lumens and clarity helps driving at night. That's at least 51% of why I did the HID install: brighter and more clear at night.
I have a 2014 6 touring.
snoWhite is offline
post #14 of 55 (permalink) Old 03-25-2015, 12:15 AM Thread Starter
snoWhite's Avatar
Quoted: 23 Post(s)
@jared
55W are annoyingly bright.
@cibersay i understand what ur saying about the blue tint. I didn't want that, but that they match the license plate lights...i like it. No shadow in the light pattern.
snoWhite is offline
post #15 of 55 (permalink) Old 04-02-2015, 05:26 PM
Originally Posted by Roger69 View Post
After reading this post I ordered the kit from DDM with the wire harness, thanks "snowhite". I installed it the same way. Coming from a car that had HID lights you really do miss them when you loose the added light output of the HID's. See picture difference of the light output. Look at both pictures as the viewer shows the same thing twice for some reason? The warm up time on these are 1-2 seconds longer than a stock D1-S or D2-S bulbs. must be the difference in the ballast
hi roger did you have to drill a hole in the round headlight lid thats directly behind our bulbs in the first gen? and also what temp did you order? thanks in advance
-Ben
1_s_LOW_mazda6 is offline
post #16 of 55 (permalink) Old 04-07-2015, 04:04 PM
Quoted: 10 Post(s)
I have the third gen car 2015. The bulbs were just plug and play. I did add a wiring harness and used a lead of the fuse box for power. the lights are 5000K. Which is bright enough for me!
2015 Mazda 6 Touring MT
Roger69 is offline
post #17 of 55 (permalink) Old 04-07-2015, 04:12 PM
Nihilus's Avatar
Quoted: 155 Post(s)
Groans: 9
I wouldn't have a problem with 6000k, but any more than that is a waste to me.
Mine are stock hid's and those are 5000k-ish, lots of light.
Nihilus is offline
post #18 of 55 (permalink) Old 04-07-2015, 04:52 PM
cibersay's Avatar
Quoted: 248 Post(s)
Yep, after 5000K you start to get color and less light. Like you said, 6000K is the highest anyone should install if the reason they put HIDs in the first place was to get more light. Otherwise just put 18000K and rebadge the trunk with Civic Type R GTR RSPEC V8 emblems, all at the same time
LeadSled likes this.
[SIGPIC][/SIGPIC]
cibersay is offline
post #19 of 55 (permalink) Old 04-14-2015, 01:50 PM
Quoted: 8 Post(s)
I just installed the 35W 5000k's in my 2014 and it was super easy - 30min total.
FYI You DON'T have to go thru the driver wheel well if you just remove the nut and the bolt that hold the fuse box to the body. This will give you enough room to get your hand down to the driver side low beam (unless you have big hands).
I LOVE how much brighter these are than the OEM H11s Halogens. The car looks so good now and you can see significantly better. Best $29 I've ever spent on this car. Highly recommended.
djkynz is offline
post #20 of 55 (permalink) Old 04-14-2015, 03:41 PM
Quoted: 6 Post(s)
Yikes
So $30 for the HIDs and an additional $22 to ground ship to FL? Yikes! Did anyone else get hit with this shipping quote?
FLDesi is offline
