DIY: Changing the Glove Box Light 3rd Gen - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 10 (permalink) Old 01-31-2014, 10:13 AM Thread Starter
Shiro Shinobi
Byakuya's Avatar
Quoted: 2782 Post(s)
Yes, this is a trivial DIY but I figured I'd post it anyways.
I took the whole assembly for the glove box light out, just so people can see how it's held in there, but really all you need is a short flathead screwdriver to pop the light housing out from the back, seen below:
The problem is that you can't see what you're doing back there, so it may just be easier to pull the housing out all together, since it's a relatively easy thing to do.
There's a single Phillip's head screw holding the little plastic housing to the back of the dash that needs to be taken out, seen below:
What I was confused about and wanted to mention here is that this screw isn't the only thing holding the housing in. There's a small plastic clip built into the housing, that wedges into the back of the dash to keep it from moving around (I presume). You can see where it wedges in in the photo below (right next to the conveniently places arrow).
**I wanted to mention this because it's impossible to see what's holding in the housing, and if you're like I am, I didn't want to break anything - so this is telling you don't be afraid to just yank it out.
The plastic clip that gets wedged in:
And that's it! Really simple, but I felt that people who got to the same spot as I did would take some comfort in knowing that, after removing the screw, you can just yank it out.
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
The Following 7 Users Say Thank You to Byakuya For This Useful Post:
Atxyde (04-30-2014), brown_wallet (03-22-2015), danstheman7 (01-31-2014), dellbx (03-28-2014), eyedocorlando (01-31-2014), Jerrycobra (05-12-2014), whiteline (02-01-2014)
post #2 of 10 (permalink) Old 05-05-2014, 02:07 AM
flyingNimbus's Avatar
Quoted: 12 Post(s)
I just replaced mine earlier today. Didn't need any tools. Just reached in and pulled the bulb out, then I popped in a 194 5smd LED in. The only trouble I had was blindly lining up the new bulb.
flyingNimbus is offline
The Following 2 Users Say Thank You to flyingNimbus For This Useful Post:
Byakuya (05-05-2014), dellbx (05-05-2014)
post #3 of 10 (permalink) Old 05-05-2014, 04:35 AM
dellbx's Avatar
Quoted: 34 Post(s)
Same here, no tools.
dellbx is offline
The Following User Says Thank You to dellbx For This Useful Post:
post #4 of 10 (permalink) Old 05-05-2014, 08:24 AM
Jerrycobra's Avatar
Quoted: 305 Post(s)
I too just pulled the bulb. i had trouble yanking that bulb out due to its somewhat awkward angle, but i eventually got it out and slipped in a new LED one. It does help that you have a dentist/ work mirror to help guide you
2014 Mazda 6 Touring Liquid Silver
[ OVT 91 octane tune ][ CS Power Series SRI+Airbox ][ Racing Beat Axleback ][Paddle Shift retrofit][ Morimoto XB35 35w 5000k HID lows ][ LED interior lights and plate lights ][ 3M FX HP Tint ][ Dipped rims and dipped trim ]
Jerrycobra is offline
The Following User Says Thank You to Jerrycobra For This Useful Post:
post #5 of 10 (permalink) Old 08-28-2018, 01:26 AM
vancityguy's Avatar
Angry
Hi guys,
So my new LED glove box bulb won't work regardless of which way I plug it in. So I know it's not a polarity issue, but it might be a wiring issue!
Any one have experience in sorting this one out? I've NEVER removed the trim of any car, ever, so I'm anxious and nervous as hell and would appreciate some guidance.
2014 Mazda6 GS with GT RIMs
vancityguy is offline
post #6 of 10 (permalink) Old 08-28-2018, 09:00 AM Thread Starter
Shiro Shinobi
Byakuya's Avatar
Originally Posted by vancityguy View Post
Hi guys,
2 Things:
1) Does a non-LED bulb work in that spot?
2) If so, check your LED bulbs themselves. Sometimes the little metal pieces that stick out around the base aren't secured well enough or are simply not touching the contacts in the housing properly. Depending on how cheap the bulbs were, you may have just got a crap batch.
Current:
, Sold:
, 3rd Generation
Byakuya is offline
post #7 of 10 (permalink) Old 08-28-2018, 02:39 PM
vancityguy's Avatar
Originally Posted by Byakuya View Post
2 Things:
Yeah, the original bulb is burnt and the LED works when I test it elsewhere...it's just that socket.
So it's either the socket or the wiring. Anyone know if this is easy to replace?
post #8 of 10 (permalink) Old 08-28-2018, 02:50 PM Thread Starter
Shiro Shinobi
Byakuya's Avatar
If the original is burnt then the problem very likely is 1 of 2 things:
1) The dying bulb caused the fuse to blow. Check your fuses behind the panel by your driver's side door under the dash. New ones cost pennies.
2) The housing is busted. You *may* need to replace the bulb housing with a new one. It appears to be part #55-431D
Current:
, Sold:
, 3rd Generation
Byakuya is offline
vancityguy (08-29-2018)
post #9 of 10 (permalink) Old 09-13-2018, 09:54 PM
vancityguy's Avatar
@Byakuya thanks. I finally figured it out and got my glove box light back on...with an LED bulb this time!
I have to add that for those, who're having trouble changing the glove box light, following this guide to the Tee is dead important. Once you do that, you'll have this sorted out in no time. Just have some faith in this DIY guide! lol.
The Following User Says Thank You to vancityguy For This Useful Post:
Byakuya (09-14-2018)
post #10 of 10 (permalink) Old 09-14-2018, 08:34 AM Thread Starter
Shiro Shinobi
Byakuya's Avatar
Glad it worked for you!!
Current:
, Sold:
, 3rd Generation
Byakuya is offline
