-   Electrical / HVAC / Lighting / Audio (https://forum.mazda6club.com/331-electrical-hvac-lighting-audio/)
-   -   DIY: Changing the Glove Box Light 3rd Gen (https://forum.mazda6club.com/electrical-hvac-lighting-audio/290938-diy-changing-glove-box-light-3rd-gen.html)
Byakuya 01-31-2014 09:13 AM
Yes, this is a trivial DIY but I figured I'd post it anyways.
I took the whole assembly for the glove box light out, just so people can see how it's held in there, but really all you need is a short flathead screwdriver to pop the light housing out from the back, seen below:
https://lh5.googleusercontent.com/-0...0/IMG_2131.jpg
The problem is that you can't see what you're doing back there, so it may just be easier to pull the housing out all together, since it's a relatively easy thing to do.
There's a single Phillip's head screw holding the little plastic housing to the back of the dash that needs to be taken out, seen below:
https://lh4.googleusercontent.com/-W...0/IMG_2128.jpg
https://lh3.googleusercontent.com/-D...0/IMG_2133.jpg
What I was confused about and wanted to mention here is that this screw isn't the only thing holding the housing in. There's a small plastic clip built into the housing, that wedges into the back of the dash to keep it from moving around (I presume). You can see where it wedges in in the photo below (right next to the conveniently places arrow).
**I wanted to mention this because it's impossible to see what's holding in the housing, and if you're like I am, I didn't want to break anything - so this is telling you don't be afraid to just yank it out. :)
https://lh6.googleusercontent.com/-L...0/IMG_2136.jpg
The plastic clip that gets wedged in:
https://lh6.googleusercontent.com/-j...0/IMG_2129.jpg
And that's it! Really simple, but I felt that people who got to the same spot as I did would take some comfort in knowing that, after removing the screw, you can just yank it out.
flyingNimbus 05-05-2014 01:07 AM
I just replaced mine earlier today. Didn't need any tools. Just reached in and pulled the bulb out, then I popped in a 194 5smd LED in. The only trouble I had was blindly lining up the new bulb.
dellbx 05-05-2014 03:35 AM
Same here, no tools.
Jerrycobra 05-05-2014 07:24 AM
I too just pulled the bulb. i had trouble yanking that bulb out due to its somewhat awkward angle, but i eventually got it out and slipped in a new LED one. It does help that you have a dentist/ work mirror to help guide you
vancityguy 08-28-2018 12:26 AM
Hi guys,
So my new LED glove box bulb won't work regardless of which way I plug it in. So I know it's not a polarity issue, but it might be a wiring issue!
Any one have experience in sorting this one out? I've NEVER removed the trim of any car, ever, so I'm anxious and nervous as hell and would appreciate some guidance.
Byakuya 08-28-2018 08:00 AM
Originally Posted by vancityguy (Post 5017330)
Hi guys,
2 Things:
1) Does a non-LED bulb work in that spot?
2) If so, check your LED bulbs themselves. Sometimes the little metal pieces that stick out around the base aren't secured well enough or are simply not touching the contacts in the housing properly. Depending on how cheap the bulbs were, you may have just got a crap batch.
vancityguy 08-28-2018 01:39 PM
Originally Posted by Byakuya (Post 5017350)
2 Things:
Yeah, the original bulb is burnt and the LED works when I test it elsewhere...it's just that socket.
So it's either the socket or the wiring. Anyone know if this is easy to replace?
Byakuya 08-28-2018 01:50 PM
If the original is burnt then the problem very likely is 1 of 2 things:
1) The dying bulb caused the fuse to blow. Check your fuses behind the panel by your driver's side door under the dash. New ones cost pennies.
2) The housing is busted. You *may* need to replace the bulb housing with a new one. It appears to be part #55-431D
https://www.jimellismazdaparts.com/i...ze/4G00D32.jpg
vancityguy 09-13-2018 08:54 PM
@Byakuya thanks. I finally figured it out and got my glove box light back on...with an LED bulb this time!
I have to add that for those, who're having trouble changing the glove box light, following this guide to the Tee is dead important. Once you do that, you'll have this sorted out in no time. Just have some faith in this DIY guide! lol.
Byakuya 09-14-2018 07:34 AM
Glad it worked for you!!
