DIY: Custom DRLs - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 2Likes
  • 1 Post By NCMAZDA6
  • 1 Post By dangle13
post #1 of 6 (permalink) Old 08-25-2013, 08:52 PM Thread Starter
NCMAZDA6's Avatar
Quoted: 43 Post(s)
DIY: Custom DRLs
I wanted to do this on my 2010 but could never find a good way. So when I got my 2014, I knew immediately what I was going to do with the foglight panels since this is the first car I don't actually have foglights on, nor do I need them with my HIDs. The beam on this car is awesome. So I made my own DRLs using 10mm LEDs from Sparkfun.com. They are great and inexpensive. I installed the bulbs in the top slot because they are almost invisible when turned off if you walk up to the car. But the cool thing is that you can install as many as you like however you like for whatever look you want. And just an FYI, no, they do not work as foglights too.
Here we go:
Started with my 10mm White LEDs and 150 ohm, 1/2 watt resistors and soldered then heatshrunk them together and made pigtails. The online calculator I used suggested 2 watt LEDs...I don't know if that will really matter, but we'll find out. I ran them on one of my store displays for about 30 minutes and they did get warm at the resister, but never hot.
I popped my foglight panels out when I installed my HIDs last week. I drilled 4 evenly spaced holes with a 3/8" drillbit which holds the LEDs perfectly. But when you drill, you also have to turn the bit to the inside so you can aim the LEDs forward instead of off to the side. Be careful here. I measured and made a template to set the panel on to get my aim right. I didn't get any pictures of that, but I'm sure you can figure it out.
Using CA glue, I glued the bulbs in place when I got them where I thought they were straight. I also painted the back side black to keep some of the light from washing out the back end. That worked pretty well. Then I made some wire extensions and they are ready to go.
I went to O'Reilly's Auto Parts and bought a couple of 2-pin trailer plugs for quick disconnects. I soldered them in, then wrapped the wire extensions in tech flex loom to protect it (I didn't have any loom at home)
Here, I cheated a little and when I made my relay to run these (I don't install anything without a relay), I tapped my constant power from my HID relay. This way, one fuse covers both, but i did install my own fuse on the LEDs as well.
This part upset me a little. I bought this fuse tap for $16 from the parts store. I figured I could pull my DRL fuse out, install this and just not re-install the DRL fuse. I was hoping that the LEDs would then function just like the factory ones...no dice. That fuse has constant power all the time. So I used the audio fuse (7.5 Amp) This way they do cut on and off with the car, though I was hoping they would cut on and off with the parking brake and putting in and out of gear. This fuse, btw, is just for the trigger side of the relay...so no current to worry about. I put a 5 Amp fuse in it and it works like a champ. They are also not blinding at night, so I am going to let them run all the time unless I see a problem. Then I will rig another relay to cut them off with the Headlights.
This is the first attempted location
Here is where it ended up.
And here is what we have.
Different amounts of zoom from the end of my driveway. The lights are actually brighter than they seem.
Crappy night pic.
After detailing the cars today
dangle13 likes this.
Alpine INE-W927BT, Alpine PDX-F4 and M12, JL Audio C5 650 Components and Coaxes, Soon to be installed : 2- JL Audio 13Tw5 (unless I change my mind)
NCMAZDA6 is offline
The Following 8 Users Say Thank You to NCMAZDA6 For This Useful Post:
ConnerSpeed6 (09-23-2015), danstheman7 (07-23-2014), Donkey Grundle (01-13-2015), kodiak12b (02-20-2015), kylekap19 (11-15-2013), mendozahtc (09-23-2015), mrlukeplease (08-28-2013), RacingSnake (08-28-2013)
post #2 of 6 (permalink) Old 03-23-2015, 10:15 PM
Quoted: 7 Post(s)
Nicely done. Looks very clean and subtle.
mendozahtc likes this.
dangle13 is offline
post #3 of 6 (permalink) Old 03-28-2015, 09:39 AM
Quoted: 32 Post(s)
Just curious about a few things. Did you disconnect the factory DRL's or remove the bulbs?
I'm assuming your first fuse tap location was powered constantly is because there is probably a relay downstream from that fuse. I would probably try to find a place to tap into the factory DRL wiring after the relay and just use that to power them. Did you try that, or is there a reason that wasn't desirable?
Current: 2016 CX-9 Grand Touring, 2014 Mazda 6 Touring, 2012 Mazda 3 Touring Sold: 2004 Mazda 6s V6 5-door
jskywalker is offline
post #4 of 6 (permalink) Old 09-23-2015, 02:23 PM
mendozahtc's Avatar
Quoted: 23 Post(s)
Looks clean man. Was thinking of something like that but seems like you beat me to it.
mendozahtc is offline
post #5 of 6 (permalink) Old 09-27-2015, 01:31 PM Thread Starter
NCMAZDA6's Avatar
Quoted: 43 Post(s)
I was going to use the fuse to trigger my relay, but it's constant power. I did not try to find the wire arms the factory one uses the high beam just at a lower voltage. So I found an ignition fuse and triggered my relay with that. I always use a relay! 2 years later and they are still going strong!
NCMAZDA6 is offline
post #6 of 6 (permalink) Old 03-23-2016, 06:18 AM
Quoted: 20 Post(s)
Wow...looks great and we can do any size or shape...awesome!
bja72774 is offline
