DIY: 3rd Gen Replace Dome/Map Lights - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 7Likes
post #21 of 66 (permalink) Old 02-04-2014, 03:44 PM
Quoted: 12 Post(s)
Originally Posted by Byakuya View Post
Pull them straight out - They're only held in by little plastic clips (with Mazda logos on them oddly enough).
They will slide towards the inside of the car, not down towards the ground. Shouldn't take more than a little bit of force.
Am I still using a mini flathead?
nounbot is offline
post #22 of 66 (permalink) Old 02-04-2014, 04:07 PM Thread Starter
Shiro Shinobi
Byakuya's Avatar
Quoted: 2882 Post(s)
Shouldn't have to from what I remember. I'll double check when I get home, but you should only have to pull (or slide) the cover away from the door, while keeping it parallel to the ground.
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
post #23 of 66 (permalink) Old 02-04-2014, 04:54 PM Thread Starter
Shiro Shinobi
Byakuya's Avatar
@nounbot I'm sorry - there IS a small slit where you need to put a flathead screwdriver in - Use that spot to pull the clips away from the door (down) before letting the cover pop off.
The 2004 model is the one which doesn't require any tools.
Current:
, Sold:
, 3rd Generation
Byakuya is offline
nounbot (02-05-2014)
post #24 of 66 (permalink) Old 02-04-2014, 06:42 PM
Quoted: 42 Post(s)
I used a flathead wrapped with a cloth to prevent scratches. There is a slot for you to pop it at the bottom of the cover.
2014 Mazda6 i Sport A/T, Jet Black Mica
Interior LED's(Map, Dome, Doors)
License Plate LED's
DDM 35w 5000k HIDs
35% side tint, 20% rear tint
Customized Corksport SRI
Custom exhaust
atlaznboi55 is offline
The Following User Says Thank You to atlaznboi55 For This Useful Post:
post #25 of 66 (permalink) Old 02-05-2014, 02:44 AM
Quoted: 12 Post(s)
So stick the flathead in at the bottom and just pop it out with some force?
nounbot is offline
post #26 of 66 (permalink) Old 02-05-2014, 10:29 AM
rickdarris2004's Avatar
Quoted: 22 Post(s)
Yep. Just did this last night, they pop right off.
rickdarris2004 is offline
post #27 of 66 (permalink) Old 02-06-2014, 12:53 AM
Quoted: 42 Post(s)
Yea, you barely have to use force.
License Plate LED's
DDM 35w 5000k HIDs
Custom exhaust
anpgator (10-16-2016)
post #28 of 66 (permalink) Old 03-28-2014, 08:30 PM
cpanzertank's Avatar
just used this guide to replace the stock bulbs with aqua blue LED's and it was so simple, thanks dude! only thing is, in the courtesy light on the door, when i pushed the LED into the slot, it easily pushed the entire thing up inside the door and i cant get it out :O it still works though and you would never know unless you popped off the lense cap and tried taking the light out
cpanzertank is offline
The Following User Says Thank You to cpanzertank For This Useful Post:
atlaznboi55 (03-28-2014)
post #29 of 66 (permalink) Old 04-11-2014, 11:22 AM
jazzdab's Avatar
Quoted: 44 Post(s)
Just replaced my courtesy, dome, vanity and license plate lights with an SMD LED kit off ebay. Couldn't change out the glove box or trunk light, though. Looks like the bulb sizes are smaller. I wonder if the bulb size was changed on the 2015 model.
Regardless, this DIY was extremely helpful!
jazzdab is offline
post #30 of 66 (permalink) Old 04-11-2014, 12:25 PM Thread Starter
Shiro Shinobi
Byakuya's Avatar
Plate lights and glove box are also 194s. I replaced the glove box light and it was a bit of a pain (but easy once I knew what to do).
http://forum.mazda6club.com/electric...t-3rd-gen.html <-- I wrote that so people don't have to wonder like I did.
Current:
, Sold:
, 3rd Generation
Byakuya is offline
brown_wallet (03-22-2015)
