DIY: 3rd Gen Replace Dome/Map Lights - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 7Likes
post #11 of 66 (permalink) Old 04-14-2013, 11:46 AM
TheBlur's Avatar
Quoted: 117 Post(s)
So I did an LED festoon swap on my rear dome lights last night. As I was installing them, I was pushing it to get in the housing since the light boards are a little too big to be horizonal. Then the light flickered out suggesting a fuse was blown. I thought screw it and would fix in the morning.
I then went out to town and when I went to lock the doors, they wouldn't lock. I then had to use the "fob touch" method and depress the stuck brake to get it to turn on again. The CEL was lit I was worried something was seriously wrong. Took the car home since I wasn't going to leave it unlocked in the city.
Got around to checking the fuse box this morning.
Its in the box under the hood and was labeled "Room 15A". She was blown all right so I did a swap and the lights worked, the locks worked and the CEL was off. Funny how the Dome light fuse stopped me from locking the vehicle.
Now we know.
2014 Mazda 6 Touring with Tech
Injen CAI & Racing Beats Exhaust
Verde 18' Black sport Rims on Kumho Ecsta 4x with Red Aluminum Lugs and H&R Springs
Thule Aeroblade Roof rack and Bike holder. Tints: Doors 35% Rear 25%
35W 6000k HID's + 35w 6000k HID Highbeams
Hella Horns with Custom Mesh Grille
TheBlur is offline
The Following User Says Thank You to TheBlur For This Useful Post:
Blackzilla (07-18-2013)
post #12 of 66 (permalink) Old 05-05-2013, 03:13 PM
mgm6's Avatar
Quoted: 6 Post(s)
I installed blue dome, map, and courtesy festoon LED's. Look great at night, will have to take night pics.
mgm6 is offline
The Following User Says Thank You to mgm6 For This Useful Post:
post #13 of 66 (permalink) Old 05-23-2013, 04:08 PM
Quoted: 53 Post(s)
Now we know.
so were you able to use the LEDs in the rear dome again?
Cloud is offline
post #14 of 66 (permalink) Old 06-09-2013, 05:52 AM
Quoted: 53 Post(s)
Cloud is offline
post #15 of 66 (permalink) Old 07-25-2013, 10:56 PM
Blackzilla's Avatar
just did it and they look good! ill probably go red later on
Blackzilla is offline
post #16 of 66 (permalink) Old 08-30-2013, 10:31 AM
Now we know.
Thanks a lot for that ^. I was replacing interior lights last night and as I was on the last bulb (passenger door light), blew the fuse. I knew I had read your post earlier in the day and pulled it back up to identify the blown fuse. Your info was a lifesaver. All said and done, it looks amazing. Especially with the black interior!
MoeMM is offline
post #17 of 66 (permalink) Old 01-31-2014, 10:09 AM
rickdarris2004's Avatar
Quoted: 22 Post(s)
Looking forward to doing this when my bulbs show up. Did this in my Focus too, it always looks good
rickdarris2004 is offline
post #18 of 66 (permalink) Old 02-03-2014, 05:34 PM
Quoted: 42 Post(s)
I'm having trouble replacing the courtesy lights, the bulb won't come out.
EDIT: Nvm, used scotch tape and it came off.
2014 Mazda6 i Sport A/T, Jet Black Mica
Interior LED's(Map, Dome, Doors)
License Plate LED's
DDM 35w 5000k HIDs
35% side tint, 20% rear tint
Customized Corksport SRI
Custom exhaust
atlaznboi55 is offline
post #19 of 66 (permalink) Old 02-04-2014, 02:55 PM
Quoted: 12 Post(s)
Can you do a How-to on popping open the courtesy light covers? I don't want to damage the cover.
nounbot is offline
post #20 of 66 (permalink) Old 02-04-2014, 03:37 PM Thread Starter
Shiro Shinobi
Byakuya's Avatar
Quoted: 2887 Post(s)
Pull them straight out - They're only held in by little plastic clips (with Mazda logos on them oddly enough).
They will slide towards the inside of the car, not down towards the ground. Shouldn't take more than a little bit of force.
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
