DIY: Changing the License Plate Lights - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 1Likes
post #1 of 32 (permalink) Old 03-01-2013, 06:10 PM Thread Starter
TheBlur's Avatar
Quoted: 117 Post(s)
Guess I'm first. The bug has bitten and more mods to come.
This is a very simple and easy mod to do and makes your rear license plate illuminate much better.
First open your trunk and start removing the black circular clips holding in the trunk liner on the lid.
If you have never worked with these clips before, take a small flat head screwdriver and pry where there is a crack in the piece until it pops out. Then just pull them out.
You will also need to remove the black hand grab plastic part on the right side. This is done by putting a screwdriver under the inner side of the piece and gently prying.
*See attached Image*
This should loosen up the trunk liner enough to have some wiggle room. If it is still tight, remove more of the clips. I have to take about 7 or so off.
Next, take a flat head screwdriver and unplug the wiring from the bulb housing.
*See attached image*
Next, pinch the inside of the bulb housing horizontally and they will pop out to the outside of the trunk lid.
Finally, pry open the light housing and replace the bulbs. I put LED's in mine and remember, if you attach them and try the lights and they don't work, try reversing them. Sometimes this does the trick.
*See attached for difference in LED vs Standard*
REVERSE STEPS
Pop the housing back in
Attach wiring
Attach circular clips. To do this, make sure the gap between the two parts are as wide as they go naturally. Then press it in like this and then press the center part to secure it.
Pop the plastic hand hold area in.
Stand back and marvel at your bright and beautiful license plate lights. WOOO
ID:	86637   Click image for larger version
ID:	86638   Click image for larger version
2014 Mazda 6 Touring with Tech
Injen CAI & Racing Beats Exhaust
Verde 18' Black sport Rims on Kumho Ecsta 4x with Red Aluminum Lugs and H&R Springs
Thule Aeroblade Roof rack and Bike holder. Tints: Doors 35% Rear 25%
35W 6000k HID's + 35w 6000k HID Highbeams
Hella Horns with Custom Mesh Grille
TheBlur is offline
The Following 5 Users Say Thank You to TheBlur For This Useful Post:
Blackzilla (07-18-2013), Donkey Grundle (11-25-2014), Gajdzin (08-09-2013), Kif (03-24-2013), Stealth_Mazda6 (06-08-2013)
post #2 of 32 (permalink) Old 03-01-2013, 09:33 PM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2853 Post(s)
Definitely first thing I'm doing to mine too - Just curious though, don't those plastic caps on the outside of the car just pop off like all the other generations?
I only took a quick look at mine but seemed fairly straight forward.
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
post #3 of 32 (permalink) Old 03-01-2013, 10:08 PM
2ndName's Avatar
Quoted: 78 Post(s)
Nice. I'll probably upgrade when they sell a complete kit for the entire car. The above picture definitely shows a huge improvement visually.
2ndName is offline
post #4 of 32 (permalink) Old 03-07-2013, 05:52 PM Thread Starter
TheBlur's Avatar
Quoted: 117 Post(s)
I just looked into the owners manual and they do advise just using a flat head screwdriver wrapped in a cloth to pry open the housing from the outside. Guess I was just curious and did it the scenic route.
Bluewolf likes this.
TheBlur is offline
post #5 of 32 (permalink) Old 03-23-2013, 11:08 PM
Quoted: 7 Post(s)
i need to do this..i have my old led's off my mazda3 gotta check if its the same
xxdjdinot1989xx is offline
post #6 of 32 (permalink) Old 03-24-2013, 05:49 PM
Kif
Kif's Avatar
Quoted: 12 Post(s)
Re: Changing the License Plate Lights
Thanks for this! One of my lights is out for the license plate anyway, so clearly I need to replace both with LEDs..!
06 Bright Island Blue V6 Hatch
Le stock.
Kif is offline
post #7 of 32 (permalink) Old 03-30-2013, 12:17 PM
javander2002's Avatar
Quoted: 8 Post(s)
If you go with the LED's make sure that the gasket that goes around the Bulb case gets a good seal to keep moisture out. I had to change mine out a few times due to that little gasket being out of place.
javander2002 is offline
The Following User Says Thank You to javander2002 For This Useful Post:
Kif (03-30-2013)
post #8 of 32 (permalink) Old 07-25-2013, 10:51 PM
Blackzilla's Avatar
just did mine and it was pretty easy just popping the housings from the outside. for some reason my lights kept going out when i was putting the housing back on but i eventually got it. thanks for this diy and keep em comin!
Blackzilla is offline
post #9 of 32 (permalink) Old 08-05-2013, 07:30 PM
Thanks for the pics. Just did mine and it looks amazing.
2014 mazda 6 grand touring
1997 Toyota supra turbo
Infamous is offline
post #10 of 32 (permalink) Old 08-09-2013, 06:12 PM
Gajdzin's Avatar
Quoted: 128 Post(s)
Thanks for this useful post! Could you advise what LEDs I should buy to fit the original bulb socket?
Marcin Bruczkowski
Gajdzin is offline
