-   Diode Dynamics (https://forum.mazda6club.com/338-diode-dynamics/)
-   -   LED Headlight Bulbs for 2009-2017 Mazda 6 Sedan Made in USA! | Diode Dynamics (https://forum.mazda6club.com/diode-dynamics/440018-led-headlight-bulbs-2009-2017-mazda-6-sedan-made-usa-diode-dynamics.html)
Diode Dynamics 05-16-2019 05:05 PM
https://i.imgur.com/MSa0pvV.jpg
SL1 LED Headlight Bulbs for 2009-2017 Mazda 6 Sedan
Diode Dynamics is pleased to offer the USA-made SL1 LED Headlight bulbs for 2009-2017 Mazda 6 Sedan
If you're looking to improve your 2009-2017 Mazda 6 Sedan’s visibility at night, you've probably seen plenty of aftermarket LED headlight bulb options. There are plenty of “high performance” LED lights on the market, but they all have their shortcomings. They're too big to install, have no hotspot in the beam pattern, or they simply stop working after just a few months!
With its compact size, optically correct output, thermally-modeled cooling, and boost-mode electrical circuit, Diode Dynamics SL1 LED Headlight Bulbs are truly the best LED headlight bulbs on the market.
Diode Dynamics SL1 Low Beam LED Headlight for 2014-2017 Mazda 6 Sedan
Diode Dynamics SL1 High Beam LED Headlight for 2009-2017 Mazda 6 Sedan
Street Legal Output. Don't be fooled by high lumen numbers or "projector specific" bulbs. Your 2009-2017 Mazda 6 Sedan’s headlights are designed to focus light. If the light source is out of focus, it doesn't matter how bright it is - you won't have a focused hotspot of light to shine down the road - just more glare. Some generic options have such a poor optical design, they might leave you wondering “how are LED headlights legal?!”
To correct this, the Diode Dynamics' SL1 LED Headlight Bulb was engineered with advanced optical design software, to perfectly match the halogen filament location. This allows the SL1 to focus light just like the original halogen headlights, preserving the focus and hotspot, with no added glare. It produces a functional beam pattern with zero glare, which we call Street Legal.
Tested to Perform. We test the SL1 in factory car headlights and measure the entire beam pattern using specialized equipment. The entire beam pattern is mapped, and we compare the total output to the original equipment, confirming that the SL1 headlight bulb shines more light in the hotspot, without adding extra glare on the road. The test results speak for themselves: in most lamps, there is 30-70% more light output in the critical hotspot, with zero glare. Thanks to optical engineering, testing, and validation in the application, the SL1 is the #1 LED headlight bulb for reflector and projector headlights.
Staying Cool. You might’ve seen led headlight kits that use large straps for cooling, or fans that just make noise. These light bulbs run hot, resulting in degradation of output after a few months. When it comes to cooling, proper engineering is required to efficiently remove heat from the bulb. In the SL1, a copper core board, thermal phase-change material, and thermally-modeled zinc casting get heat to the base, where base fins release it, designed for aerodynamic performance in conjunction with the flow rate and pressure of the Sunon bearingless micro fan. The result is a highly effective and reliable cooling system, keeping the SL1’s LED chips running at maximum potential.
Fitment. With its patented design, installing the SL1 LED headlight bulb is simple and straightforward, requiring NO cutting or modification. There's no hanging metal straps, just a compact bulb that plugs right into your 2009-2017 Mazda 6 Sedan, with a nylon-reinforced shroud. Only slightly larger than a standard halogen bulb, it fits behind dust caps and in tight spaces. The base sizes are keyed specifically to fit your vehicle, not one-size-fits-all! And the compact driver easily tucks away.
Reliability. Every part of the Diode Dynamics' SL1 LED Headlight Bulb is engineered with more expensive OEM-grade features to assure quality, such as the Sunon MagLev fan and PCB wire connectors" In short, these are designed, tested, and built to a much higher standard than your average imported led headlight conversion kit. The Diode Dynamics' SL1 LED Headlight Bulb will keep performing in your 2009-2017 Mazda 6 Sedan for years, and is backed by a three-year warranty.
Specifications
Measured Lumens: 1630 (per bulb)
Color Temp: 5700K (cool white)
Power (watts): 20.2
Operating Voltage: 5-16V
Current (amps @ 13.2V): 1.58 Polarity:
Polarity Specific LED Emitter: Luxeon Z ES
Connector(s): OEM-Size Plug and Play
Driver Features: External, Waterproof, Constant Current
Materials: Copper PCB, PP-TD30 Base, Zinc Heatsink
Cooling: Active, Mag-Lev Microfan
Compliance Ratings: FMVSS108 Beam Pattern, SAE J575 Durability Test
Click To Order Your 2009-2017 Mazda 6 Sedan Bulb Replacements:
If you have any questions, please don't hesitate to post, PM, email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Jake H.
Diode Dynamics
Mad Myche 05-16-2019 08:01 PM
Are these street legal for USA
Diode Dynamics 05-17-2019 12:27 PM
Great question!
The SL1 is DOT and FMVSS108 Beam Pattern compliant (be wary of any LED bulbs labeled "DOT" approved, the DOT doesn't actually "approve" products like that).
Jake H.
Diode Dynamics
Diode Dynamics 05-17-2019 05:25 PM
Are you looking to make the switch from halogen to LED headlight bulbs? Before you do, check out this video to ensure you choose the best one.
Good optical focus means more light further down the road where you need without any glare. We put together this video to highlight what to look for when choosing an LED headlight bulb for your vehicle. Check it out! And don't forget to shoot us a PM for free USPS shipping on any U.S order!
Jake H.
Diode Dynamics
Diode Dynamics 05-29-2019 11:56 AM
Think having LED headlight bulbs shine light 360-degrees is a good idea? Think again! Check out this video to see why!
Diode Dynamics 06-03-2019 05:48 PM
Don't forget to shoot us a PM for FREE USPS shipping on ANY U.S order!
Jake H.
Diode Dynamics
Diode Dynamics 06-04-2019 12:42 PM
How hot an LED headlight bulb gets has a BIG impact on how bright it will be over time and how long it will last. Check out this video to see if your headlights are getting too hot!
Diode Dynamics 06-21-2019 02:49 PM
In our latest video, we answer one of the most popular questions about headlight upgrades: Which is better, HID or LED? Check it out!
Jake H.
Diode Dynamics
Diode Dynamics 07-05-2019 05:36 PM
July 4th sale! 20% off all diode dynamics products!
Don't forget to shoot us a PM for free USPS shipping on any U.S order!
Jake H.
Diode Dynamics
Diode Dynamics 07-09-2019 01:59 PM
Measuring Headlight Output | Diode Dynamics
How are headlight output patterns measured at the factory level? How do you test to see if a headlight is meeting SAE and DOT beam pattern requirements? Here at Diode Dynamics, we've invested in a goniometer to accurately measure and map the entire beam pattern and ensure our products are adding light output without adding extra glare.
Check out the video to see how it works!
Jake H.
Diode Dynamics
