-   Diode Dynamics (https://forum.mazda6club.com/338-diode-dynamics/)
-   -   Mazda 6 Fog Light LED Bulbs! Comparison Photos Added! New USA Made SLF! (https://forum.mazda6club.com/diode-dynamics/365561-mazda-6-fog-light-led-bulbs-comparison-photos-added-new-usa-made-slf.html)
Diode Dynamics 09-01-2015 04:18 PM
Diode Dynamics carries LED bulbs for replacement of your fog lights, in all major sizes. They are available in HP, XP, and SLF styles. This will make your fog lights a nice bright white that closely matches factory-equipped HID lighting! Just simple plug and play, replace the bulb and you are good to go!
Diode Dynamics carries the brightest, highest-quality bulbs on the market. We are here if you need us for support and service. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Brightness:
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
HP48: 265 lumens. Lower brightness than factory, but still provides the crisp white, modern color of LEDs.
XP80: 510 lumens. Similar brightness to factory.
SLF: Street Legal Output. Much brighter than factory. These are bright! Made in USA!
Bulb Design
HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Included in your order is TWO Diode Dynamics LED BULBS (to fit your Mazda 6).
Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
Diode Dynamics: Fog Light LEDs for 2003-2005 Mazda 6 Sedan
Diode Dynamics: Fog Light LEDs for 2006-2016 Mazda 6 Sedan
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics 03-24-2016 03:04 PM
http://www.diodedynamics.com/images/...2_Yellow_3.jpg
Customer Submitted photo with Yellow XML2 Installed
Nick C.
Patrick T. Halpin 04-20-2016 11:17 PM
Do you have green, say between 510nm and 540nm color frequency?
Diode Dynamics 04-21-2016 09:49 AM
We don't offer a single color green LED replacement, but our RGB multicolor bulb can create any color via remote control
http://www.diodedynamics.com/images/...RGB%20Fogs.jpg
Nick C.
Diode Dynamics 10-10-2016 12:45 PM
New Comparison Photos have been added!
http://diodedynamics.com/images/mazd..._H11_XML2y.jpg
Yellow XML2 Installed!
Nick C.
jpjr50 07-25-2017 07:57 AM
Question - is it legal for the fog lights to be this bright? I was told fogs should not be half as bright as headlights or they won't cut into the fog (just glare instead). I know we buy most LED's for looks but what about what they are actually made to do?
Diode Dynamics 07-25-2017 09:18 AM
Fog lights are an auxiliary lighting location. Our LED replacements produce more usable output for safer nighttime driving, but many customers purchase them specifically for cosmetic appearance purposes.
If you are looking for something more effective in foggy conditions, I suggest going with a yellow color temperature:
Nick C.
jpjr50 07-25-2017 10:37 AM
Thanks!
TechSpecs 07-25-2017 11:27 AM
Looks great!
Diode Dynamics 01-29-2018 11:49 AM
http://www.diodedynamics.com:8080/im...ut_collage.jpg
Curious to see how the new Diode Dynamics, USA-Made, SLF performs in fog light locations? (2015+ F150 shown for comparison)
