Stereo upgrade project 2016 M6 GT - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 4Likes
  • 1 Post By shawndoggy
  • 1 Post By tickerguy
post #1 of 10 (permalink) Old 04-18-2019, 01:36 PM Thread Starter
shawndoggy's Avatar
Figured I’d start a post as a place to log my progress. I’m figuring that this is going to be a 6 month project if I am lucky.
Goals aren’t that crazy:
Keeping factory HU with PAC aoem-maz2 for integration.
Infinity kappa 6.5” three way components in the front doors / dash using factory location.
Kicker comp RT shallow 10 in the trunk above the spare.
Amp is a Rockford Power t1000-4ad, which will give 250w to each door channel, and 500w to the sub. I plan on using HU power for rear fill.
I’ve done lots of stereo projects in the past and each has something I end up regretting. Usually because I get impatient trying to work fast. So I’m giving myself all the time in the world for this one.
93blkongreenpro likes this.
shawndoggy is offline
post #2 of 10 (permalink) Old 04-18-2019, 01:42 PM Thread Starter
shawndoggy's Avatar
Rough mock up of box and amp rack
Test fit of carpet
Getting started in earnest
Top of box is cut
Starting the fiberglass work
Popped the glassed-in bottom out for further coats on the inside
post #3 of 10 (permalink) Old 04-18-2019, 03:23 PM
tickerguy's Avatar
Quoted: 906 Post(s)
Groaned at 7 Times in 7 Posts
I strongly recommend figuring out a way to get forced ventilation (airflow) through the amp section of that box; I suspect you're going to regret it in a major way down the road if you do not. You'd be utterly shocked at how fast electronics that are running material amounts of power get hot in confined and reasonably-insulated spaces (which that space definitely is and will be!)
shawndoggy likes this.
tickerguy is offline
post #4 of 10 (permalink) Old 04-18-2019, 05:09 PM Thread Starter
shawndoggy's Avatar
Plan is to build a new carpet piece which will have integrated mesh venting for the amp rack and the sub. Will also (maybe/probably) run a cross ventilation fan like PAC CF-1. Like I said it's gonna be a long process!
post #5 of 10 (permalink) Old 04-18-2019, 10:16 PM
tickerguy's Avatar
Quoted: 906 Post(s)
IMHO two small box 12V fans (e.g. 80mm) at opposite ends of the box (one push, one pull) wired to the amp turn-on circuit so they run when the amp does and establishes a positive airflow through the amp box. Fortunately they're trivially and cheaply available (PC fans are 12V.) That'll do it; you don't need a lot of airflow, but you do need positive airflow. Sleeve bearings are fine if they're mounted vertically.
post #6 of 10 (permalink) Old 04-18-2019, 11:02 PM
93blkongreenpro's Avatar
Quoted: 116 Post(s)
This is going to be nice.
How is your tuning going to be achieved? Are you going to run a processor of some sort?
*2014 M6GT, Maxie G, stock as she can be.
*2009 Mazda 3 Sport - Sold
*1993 Mazda Protégé, Sell Pending*
93blkongreenpro is offline
post #7 of 10 (permalink) Old 04-19-2019, 12:28 PM Thread Starter
shawndoggy's Avatar
As of right now no tuning. Trying to keep it simple. Front stage will be well powered passive three way, rear fill from HU power, modest single sub in the trunk with adequate power.
Haha sadly 99% of my listening in the car these days is podcasts anyhow! This is more of a passion project than anything else ... a chance to take it slow and get as close as I can to something I’m happy with, as a white collar shade tree hack who is relying on his 12v self-training and 30 year old middle school shop classes (supplemented with some YouTubing).
Dunno about you guys but I feel like 75% of my “work” on this sort of project is just staring at stuff.
post #8 of 10 (permalink) Old 04-20-2019, 02:29 PM Thread Starter
shawndoggy's Avatar
Countersinking the mounting ring for the sub
Test fit
post #9 of 10 (permalink) Old 04-20-2019, 04:24 PM Thread Starter
shawndoggy's Avatar
Wire routing cutouts for the amp rack
post #10 of 10 (permalink) Old 04-21-2019, 07:03 PM Thread Starter
shawndoggy's Avatar
Glued and screwed
Decided to use the router for some cross vent holes on the amp rack while I had a jig set up.
Similar Threads
2016 Touring stereo Polk Audio & Kenwood /sound deadening upgrades BrianU In Car Electronics 4 11-25-2016 06:23 AM
2016 - Stereo Volume Control on Steering Wheel? Mr.Mojo 3rd-Gen 5 08-17-2015 08:00 AM
Bose Stereo Upgrade Bantha In Car Electronics 4 03-22-2003 05:48 PM
