Car audio install help - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 2Likes
post #1 of 14 (permalink) Old 09-29-2018, 04:33 PM Thread Starter
Hello all. 2014 M6 gt with 11 speaker bose.
Couldnt find my answer here through extensive searching on the forums. I have a quick question regarding the bose amp.
The green harness and black harness that contain the speaker wires, are those harnesses the output speaker lines of the amp going to the speakers or are they input harnesses to the amp coming from the head unit? I just want to make sure im tapping signal after the bose amp and not before as audio controls instructions on wiring the lc6i.
My goal is to install the lc6i with 5 channel amp, replace the front door subs with midrange speakers and add a sub in the trunk....so all 4 doors are midrange.
Any help is greatly appreciated.
Thanks
Jdaniels
Jdaniels is offline
The Following User Says NO Thank You to Jdaniels For This Un-useful Post:
Berber (01-20-2019)
post #2 of 14 (permalink) Old 10-03-2018, 12:53 PM
MZ6Alex's Avatar
Quoted: 27 Post(s)
I think your odds of getting a clear answer on this are rather low. There's just not much info out there unfortunately and the wires colors are always different from year-to-year which further complicates things. To answer your question in a general sense the harnesses have to contain both. There must be an inputs to the amp from the HU and outputs to the speakers. From information I've gathered around the web the green harness typically contains speaker outputs, which would mean the inputs are likely on the larger black harness, but for lower power speakers like tweeters or the center channel (because BOSE), there could also be outputs from the larger black connector as well. Since you're replacing most the speakers anyways, my suggestion would be to do a continuity check with the wires in the doors to see where they're routed back to in the amp harness. That would be the only way to get a definitive answer on what wires go where. Unless someone has a pin-out of course.
MZ6Alex is offline
post #3 of 14 (permalink) Old 10-03-2018, 07:11 PM Thread Starter
@MZ6Alex
Hey, thanks for the reply. I do have the pinout diagrams for my particular year(2014). Upon reviewing the pinout diagram, it shows some speakers on the green harness and others on the black harness. It also shows on the diagrams that the speaker wire colors actually change from the bose amp to the actual speaker. So at the bose amp u have 2 color codes, and then at the speaker they are different color codes. Im assuming mazda changes wire run colors to make it difficult for owners to upgrade audio outside the dealership. Anyway,, regarding doing a continuity test, if i put positive/negative leads of a multimeter in the proper labeled pinouts(from the diagram) of the harness would that give me a tone out of the speaker? If that would work, it would answer my question that the green harness is the output speaker lines going to the speakers and indicate exactly what color codes are for each speaker at the bose amp....what i dont understand about the pinout diagrams is why the speakers are divided between the 2 harnesses....this is what it shows,
Green harness:
Front left and right dash speakers
Rear door right speaker
Left and right rear deck speakers
Black harness:
Front left and right door speakers(subs)
Rear door left
Can u or anyone confirm this? I find it quite bizarre but following the pinout codes this is what i understand.
In the end like i said in my original post....i just want to wire my lc6i after the bose amp as recomended and not before it.
Jdaniels
Jdaniels is offline
post #4 of 14 (permalink) Old 10-03-2018, 11:57 PM
xthefletcher's Avatar
Quoted: 4 Post(s)
I was in your shoes last year when I was wiring the amp for my subs. I too have the bose system for my 2015 touring mazda 6. I canít remember exactly where I tapped into but I was right and it works great.
This pic is from my notes when I did the install for the colors of wires I tapped into. Ignore the last item on each line (yellow hot white hot stuff) that was specific to the lines I used to go to the amp I installed for the sub.
2015 Mazda 6 Touring Deep Crystal Blue
- TRS HID Headlight Kit
- OEM Fog Lights and stalk
- Interior LED kit
- Programmable automatic foot well LEDs
- Blacked out front emblem
- Debadged rear bottom emblems
- Hardwired Pruveeo Dashcams
- Hardwired Uniden DFR6 Radar Detector
- 2 10" Kickers
- Aftermarket seat warmers
xthefletcher is offline
post #5 of 14 (permalink) Old 10-04-2018, 12:32 PM
MZ6Alex's Avatar
Quoted: 27 Post(s)
It's definitely bizarre the wire colors change. I hadn't even realized this myself (have some changes planned for my 2018, but haven't had the time to sit down and really look at things closely). I don't think they would do this to make upgrading the audio system difficult, but I would be curious as to why this is the case. Also in your model of vehicle I believe the front mids and tweeters are connected in parallel, so this likely makes it further difficult to tell which set actually makes it's way back to the amp.
A continuity test is done by setting your multi-meter to continuity mode as indicated by the schematic image of a diode: . If you then plug the leads into their normal voltage measuring slots and touch them together the multi-meter should read "0". If your multi-meter has a beeper/buzzer that should also sound when you touch the end of the leads together (sound may need to be manually turned on). The test is to determine if the wire goes directly from one point to another, or if there are other electrical components/shorts in the way. It's similar to testing resistance but in this case we don't care about the resistance measure, we only just want to know if the wire is continuously connected.
The way I would do this is to take the speaker out of the door & disconnect it (since you're doing this anyways), then connect one end of the multi-meter to each one of the speaker wires at time in the door, and probe each output wire at the connector for the amp. Do this for both wires that connect to the speaker in the door and you'll know for sure which wire is which, plus you'll also have the benefit of knowing you'll have the correct speaker polarity for your aftermarket speakers when you go to hook those up.
Regarding the amp inputs/outputs and their respective harnesses, these amps are pretty universal. The basic shell design (probably PCB as well) is extremely similar-if not the same, for the entire Mazda6 generations of vehicles, so it would be far easier/cheaper for Bose to just reroute output channels to other available pins rather than go through the trouble of redesigning a new shell and changing the plugs just to compensate for a couple extra speakers.
EDIT: So I had changed out my 3x front channel speakers last week and visually at least it appears the wire colors going to those speakers correspond correctly to the wire colors at the amp harness. I can't confirm for sure without a multi-meter this is the case, but from the pin locations on the green harness and how all 3x wire pairs are exactly next to each other horizontally, I doubt there's any change in wire color from the speakers to the amp for me. I'm not sure why things are different for you.
MZ6Alex is offline
post #6 of 14 (permalink) Old 10-04-2018, 10:53 PM Thread Starter
Thanks for the replies again. I'll probably give the speaker continuity check probably next week hoping that I get some free time. With regards to the wires changing color mid route, i have no idea. My 6 was actually manufactured in japan. Not sure if that might have something to do with it. Zoom in on the front door speaker lines from the amp to the speakers in this screenshot. Tell me what you think. As i see it, the color code changes.
Name:	Screenshot_20180828-212628_Samsung Internet_1538707915176.jpg
xthefletcher likes this.
Jdaniels
Jdaniels is offline
post #7 of 14 (permalink) Old 10-05-2018, 01:02 PM
MZ6Alex's Avatar
Quoted: 27 Post(s)
It definitely appears the wire colors change for the front speakers, but I can't see why and I also don't see the tweeters on that diagram either. They would have to run in parallel somehow.
MZ6Alex is offline
post #8 of 14 (permalink) Old 10-05-2018, 02:06 PM Thread Starter
Those are the front door subs. The tweeters do run parallel with the top dash 3.5"mids...i have rhat diagram as well..i will take a look at it later tonight and confirm if they change colors as well from amp to speaker
Jdaniels
Jdaniels is offline
post #9 of 14 (permalink) Old 10-05-2018, 05:31 PM Thread Starter
So I found the diagram. The tweeters and 3.5 mids in the dash are same color code from amp to speakers and wired in parallel, however its showing again that both rear door speakers change color at the speakers. Why?
Would you know if the speaker pop test would work( battery with wire leads touching +/- of speaker) from the harness pinouts? Or is it too long of a run.
Name:	Screenshot_20180828-212615_Samsung Internet_1538774836526.jpg
Jdaniels
Jdaniels is offline
post #10 of 14 (permalink) Old 10-05-2018, 06:16 PM Thread Starter
@xthefletcher
Hey whats up. If i was just adding a loc for subs it would be very simple, but because im adding a 6 channel loc, i need to get a full range signal, so i can eliminate the sub frequencies going to the front doors and apply midrange frequencies there instead. I will have a sub in the trunk instead.
Jdaniels
Jdaniels is offline
