Yes Mazda Connect or MZD Connect has CP and AA.
Installation:
Must install new Firmware FIRST 70.00.xxxx.up
Then remove the old AUX Hub and replace with new Modified AUX Hub.
Remove old single USB Data Cable from old AUX Hub to CMU (under touchscreen).
Install the TWO new Data USB Cables from new AUX Hub unit up to CMU unit.
Then you run it, you will have new CP and AA working.
If they don't install new Firmware first with the old parts it will not work after new parts are fitted.
Anyway, when one of you guys gets your free upgrade can you let us know what the Firmware number is on screen for North America
NA N, I think it will be an updated or later version that is currently in use in Europe (they were first).
EU N Firmware is 70.00.021A EU N
ADR is 70.00.021A 4A N
And yes all owners with Mazda Connect can buy the parts for Retrofit Upgrade.
Here are the new Mazda Part Number...
TK78-66-9U0C AUX Hub New...worldwide.
USB Data Cable Set (2 of), I have the EU and ADR Part Numbers but I have been told the USA numbers could be different.
Also factory installation (Japan) starts with 2019 MY for the Mazda 6 and CX-9 and others, but ONLY in top spec models above GT.
Anyway sorry for the boring dribble, can someone let us know what the Firmware version Number is confirmed for USA.
Ash
