Officially official, Android Auto/Apple Carplay for 2018 Mazda 6 - Page 33 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 49Likes
post #321 of 324 (permalink) Old 01-13-2019, 12:21 AM Thread Starter
Dougspeed's Avatar
Quoted: 113 Post(s)
Originally Posted by bacevedo View Post
So the new mat still has the same problem as the old one. It pops off all of the time. Since many of you are having the same issue I suspect it's a design flaw. Maybe if enough people complain they'll come up with a fix that we can retrofit back in. Not that it's a huge deal, but I do think they consider this a safety issue as the whole reason for the clips is to keep the mat from moving up under the brake and accelerator pedals.
I actually never got around to bringing the car in to the dealer to fix this, but I had a hunch as to what was causing it, the rather large safety label on the underside of the mat. I cut it off and voila, the mat hasn't unclipped once since. If you take the mat off, you'll notice that the backing acts kinda like velcro and actually grips the carpet unlike the usual floormats that have rubber backing with those sharp nubs/spikes. With the label in the way, that portion next to the clip never grips the carpeting which allows it to shift and pop up off the clip. Now that the label has been cut off, the full mat grips the carpet and doesn't unhook anymore. YMMV but it's worked for me so far.
Dougspeed is offline
The Following 2 Users Say Thank You to Dougspeed For This Useful Post:
Bill_k (01-13-2019), Mz6GreyGhost (01-14-2019)
post #322 of 324 (permalink) Old 01-13-2019, 01:05 AM
zPacKRat's Avatar
Quoted: 23 Post(s)
Groans: 11
I did that too, when I first set it up. I can't remember for sure, but I think you have to remove the pairing from your car within the Android Auto app on your phone. Once you do that and plug in again, it will start the setup process over.
Thanks, appreciate knowing it's not just me.
2006 Mazda 6s Auto with 145,000 Miles (traded for 2015 Touring)
2015 Mazda 6 Touring w/6Spd Manual (having an ex wife allows for having a manual again
)(traded for 2017 Touring)
2017 Mazda 6 Touring w/Auto (done rowing gears and the skyactive auto has proven to be far more reliable than the one in my 2006)
zPacKRat is offline
post #323 of 324 (permalink) Old 01-14-2019, 11:11 AM
bacevedo's Avatar
Quoted: 25 Post(s)
That is awesome and great timing!
I had been paying attention lately to the mat as I was getting in and out of the car. I had noticed that it seemed to slide forward under certain conditions depending on the way I depressed my foot. I had originally thought it was unsnapping because the mat had downward pressure applied in the middle causing the corner to rise up and unsnap. But after paying attention I noticed it was actually the forward slipping movement that was causing it. I thought to myself "why didn't they use the velcro type of material like they did on the rear mats to make it stick?" I hadn't even thought about the label causing it because I had forgotten it was there!
I cut mine off as you suggested and it does seem to stick better. Haven't driven enough to say for sure, but so far it's holding.
Thanks!
Dougspeed likes this.
2018 Signature
White Pearl - Chestnut
bacevedo is offline
post #324 of 324 (permalink) Old 04-06-2019, 09:55 AM
Okay...so do I have to go through all 33 pages for a synopsis of this, or is there a page where everything to do this install yourself is covered?
TNDragon is offline
