Audio upgrade (finally) (pics) - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 1Likes
  • 1 Post By Zeffer
post #1 of 10 (permalink) Old 01-25-2017, 10:57 PM Thread Starter
Talking Audio upgrade (finally) (pics)
I bought the car last July to see that the sound (non bose) is abysmal at best. Even after replacing the door speakers and tweeters, it was still lacking. After months of loafing and half-a**ing, I finally added a sub and an amp. Was very easy and turned out pretty clean. MTX is my main choice for subs and amps, but instead went with this from Rockford Fosgate:
https://www.crutchfield.com/p_700BPK....html?tp=61893
I am beyond pleased with the result! As of now, I'm staying with the factory head unit.
ID:	198834   Click image for larger version
ID:	198842   Click image for larger version
It is what it is.
Phoenix White is offline
post #2 of 10 (permalink) Old 01-26-2017, 09:31 AM
Banned
Quoted: 20 Post(s)
Groaned at 5 Times in 3 Posts
Do you have to keep the rear seat down to listen to the sub?
What happens when you need to remove the spare tire lol
Mazda6Power is offline
post #3 of 10 (permalink) Old 01-26-2017, 09:40 AM
Zeffer's Avatar
Quoted: 171 Post(s)
Fellow subwoofer owner, no. Subs are best when aimed at the trunk, and the sound reverberates through the car into the cabin.
Phoenix White likes this.
Jacksonville, FL
Zeffer is offline
post #4 of 10 (permalink) Old 01-26-2017, 10:48 AM
Quoted: 78 Post(s)
I have the Kenwood KSC-SW11, a small powered subwoofer that just didnít have the power and size to get the job done when mounted in the trunk, so I had to find an alternative location that would work. I know some members have mounted it under the passenger seat and it would just fit, but that location would interfere with passenger foot space. Because of its size, I found a great place to mount this little bad boy, against the front of the back passenger seat! I know the picture isnít so great and I can take another picture if needed, but the size of this unit is perfect for this location. The mounting bracket on top of the unit slide under the bottom of the seat holding it in place, a great solution for me!
BrianU is offline
post #5 of 10 (permalink) Old 01-29-2017, 10:03 PM Thread Starter
I do not. And if I need to remove the spare tire, I can just lift it up and remove it as normal. It's not large nor does it take up a lot of space.
It is what it is.
post #6 of 10 (permalink) Old 01-29-2017, 10:21 PM
Banned
Quoted: 20 Post(s)
I may do the same setup in the future. It flows well with the carpet. Did you install it yourself or had a shop do it?
How did you/they put the amp on the side of the carpet? Do they have to drill holes?
How do you install this, did you already have experience with this or follow a guide or installation?
post #7 of 10 (permalink) Old 03-02-2017, 02:02 AM
Quoted: 11 Post(s)
Very clean install! Where did you ground the amp in the trunk?
I'm going to be installing my setup this weekend. Right now my amp is on the box b/c it wouldn't fit anywhere cleanly mounted in my old Audi Avant. May end up mounting to back of seat or side of trunk like you.
"Unfortunately" I have a Bose system and they apparently have a 45hz roll off, sucks but I'm hoping for a little more bump. In all honesty though, with Centerpoint turned on it sounds really good.
Baydestrian650 is offline
post #8 of 10 (permalink) Old 09-14-2017, 03:46 PM Thread Starter
Yes, I drilled holes. And yes I have experience
It is what it is.
post #9 of 10 (permalink) Old 09-14-2017, 03:48 PM Thread Starter
I used a metal point just below the back rear seat.
It is what it is.
post #10 of 10 (permalink) Old 01-23-2018, 09:38 PM
That is the cleanest trunk I have ever seen! lol Nice work on the install. I've used rockford subs in the past. They are pretty good for how cheap they are.
JamesDavis26 is offline
