-   In Car Electronics (https://forum.mazda6club.com/276-car-electronics/)
-   -   Bose Nav Radio Upgrade & Bluetooth Fix (https://forum.mazda6club.com/car-electronics/383737-bose-nav-radio-upgrade-bluetooth-fix.html)
diggscreed 03-05-2016 04:26 PM
9 Attachment(s)
I haven't seen anyone do this upgrade yet so I thought I'd share my experience. I own both a 2010 Mazda 6 GT and a 2013 Mazda 6 GT. There are certain features they took away in the later years but others they added I wish my '10 had.
One such feature is the Existing Bose Nav radio. They added real-time traffic updates and RDS to the AM/FM radio streaming. I like that I can see whats playing on the radio as I drive. Frankly, even in 2010 RDS was an old technology that's been around forever. It was in decks I installed in the 90's. (get with the new age Mazda). But ANYWAY.........
I purchased a scratched up Bose Nav unit from ebay. Saw it'd been sitting there for sale for like half a year and way overpriced. The seller dropped it to a hundred bucks or so finally and I bought it.
Now a new one for model years 2011-2013 is like 4 grand F.Y.I..........so a hundred bucks to get the extra feature was a deal. So what am I gonna DO about the scratched up LCD screen you ask? Well..swap it out! I thought to myself, that can't be THAT hard?
Since nobody here had done it....I took a chance at being the guinea pig and potentially screwing my '10 Nav radio up! But I wanted a unique project so I figured "meh".
So the face plate easily swaps out with the radio chassis. What you will find is that the BACK of the radio of a 2011-2013 Bose Nav, does NOT have a plug in the side of it for the factory antenna amp to derive power from.(blue wire) The OEM antenna plug uses a square (photo's below) and the 2011-2013 Nav radio just has a straight Motorola jack. So I assume they changed where the antenna amp derives its 12v power from and instead of from the radio, its powered from elsewhere in the car. To get around this, I simply bought a metra harness adapter and hardwired the blue power wire into the ACC wire in the back of the main radio harness. That way the antenna amp in the headliner gets juice only when the car is on and my battery doesn't run down.
With that fixed, its all plug and play after that. I happen to have a new map DVD. Make SURE you eject it out of the old radio and insert it into the new one. Otherwise the program will not load and you will get a screen error. Radio will not function without this DVD in at all times.
One consideration to take into account here; is that by the time you have done this, you will no longer find that your Bluetooth will function with the new radio. I assume this is because the new firmware in the newer Bose Nav units does not match the profiles built into the old Bluetooth module. I found that while Bluetooth function of the phone was still there; I could not get my phone-book to download anymore!
So..........you have to swap out the module with a newer one. It's really the only way to solve a multitude of issues. Example.............
From the first day I ever bought my car new........I never had the Bluetooth phone ever display title and song info from my friends iPhone 4. (at the time. My friend has an iPhone 6 now) Regardless, never worked. Nor did I get consistent caller ID display across the nav screen! Only and always a phone number. Once I upgraded to a new module (built in December 2015), all the sudden, my phone-book downloaded, the calls that came through displayed the persons names, and the metadata of the music on my phone displayed like normal. Also; for those of you who have had a buzzing noise when selecting SAT, or Bluetooth, I found the newer Bose Nav had remedied this too! I guess it was an internal design flaw of the '09-'10 radio. I suppose the circuitry inside the '11-'13 radio has been improved. I know that my 2013 never had that problem, but my 2010 always did.
There is no way to update the module with firmware, as it is only a hardware device. Sadly, getting the most up to date one you can is the only real way to fix these Bluetooth issues. Its not something that's gonna be under a warranty; it's just technology catching up. And the hardware had been upgraded as long as they still make new modules. So I guess I killed two birds with one stone on this project. All be it a costly one. Keep in mid the Bluetooth module is located behind the glove box on the passenger right fender dash support structure. Its only being held on by two nuts that screw onto the threaded studs that are welded onto the structure. So I just got my right angled socket wrench and took them off. You kind of have to do a whole 90 degree L shapped turn song and dance to get the module and it's attached L bracket to come out of the passenger compartment, but it can be done.
Now you MAY luck out if you can find one off a 2013, but in MY 2013, the phone number grabs the first entry in my phone-book and displays it across the screen. If JOHN calls me, it says Ann. If Bob calls me, it says Ann. That's it. Even in 2013, apple and the module (made in 2012) never played nice. And I believe the metadata in that car was blank too.
So if anyone wants to retain the factory upgrades from 2011-2013 in their 2009-2010; this is the way to do it.
My goals are to get the new features they put in the 2013 and have them in 2010. As I get to keep the fun features they built into the 2010 like auto passenger window roll down, key fob windows roll down and sunroof open, etc. I hate they deleted that off the 2011-2013's. BUT.........they added folding mirrors with blinker turn signals, auto lock when vehicle approaches 15mph, and auto unlock on engine stop, and the newer Bose Nav radio described here, with real time traffic and RDS. So at some point......I will have the best of both worlds. If Mazda had caught up with the times in 2010 like the rest of the world, guys who like to tinker like me would have nothing fun to do I guess?
Hope this helps someone!
diggscreed 03-05-2016 04:28 PM
5 Attachment(s)
Additional Photo's. iPhone Bluetooth metadata now functions.
jhill1977 04-16-2016 10:29 PM
I will be keeping my eye on this thread. Sadly, the Bluetooth unit I was using with the Bose display audio doesn't work with my '09 factory NAV unit. I'm able to import my contacts, but as expected i have no meta-data displayed on my radio.
Justin
diggscreed 04-17-2016 01:00 AM
Justin
Right. As I may have mentioned, the dang modules are so outdated they are useless. Johnson controls is still making them; and if you ordered a new one same part number as the one you have; you will get a manufacured date of 2015 or later. The chipset inside the module should surely fix the outdated bluetooth profiles and metadata sync problem. It did for me? And like you I also could not import my phone contacts after the radio swap. But the new module was plug and play and once I did that; everything worked flawlesly. (so annoying it comes down to the chipsets) but thats the second gen tech for ya? I think 3rd gens just get an ecu flash update or something? I dunno; but the interface is more up to date on those. Guess we are stuck with upgrading the actual "hardware" on the second gens. But it works. Yeah lemme know if you find a better/cheaper solution? I always seem to take the hard route with these things...... :-(
mervinp 05-22-2016 10:01 PM
Do you have a picture for where this is located? My BT Audio is permanently grayed out - even after battery reset procedure..
Cheers
M
diggscreed 05-29-2016 11:54 AM
1 Attachment(s)
Cheers
M
I mentioned it's exact location, but if you need a graphic then here is the detail of it.
You did not mention what YEAR the car you have was, so I am assuming it's the same as mine. Regardless; all 2nd gen's are in the same location. But the module part numbers differ.
If you are saying it's "greyed out", then that means you have the nav radio. And as such, have you "paired" your phone to the radio using the Bluetooth phone-pairing buttons in the menu screen? (I realize that's the age old "Is it plugged in" question, but since you haven't provided that info, I have to ask because maybe that's the problem.)
Also since you are asking for the location of the module; I am presuming you are looking to mess with it as if THAT is the problem? So I have to ask before you go down that road. Because that's extra leg work in a couple different directions that you may not have to go.
mervinp 09-02-2016 04:18 AM
It's the Australian Mazda 6 2009 ( so it's 2nd gen ). Thank you for the diagram. I will check the menu pairing option first.. failing that do I need to try and source a 2011-13 bluetooth module?
Cheers
M
diggscreed 09-03-2016 05:51 PM
Cheers
M
Yes. I can almost guarantee you will need to source another module. But make sure you buy it brand new. The part numbers for an '09-'10 Mazda 6 are different than one for a '11-13. Or at least it is here in the states. Make sure you buy one that is for your '09. Same part number. It will just have a different chip-set in it and new firmware. It should import all your meta-data after that.
Sourcing one from a later year won't help you because not even my '13 Mazda 6 had meta-data importation. It wasn't until I upgraded both my 2010 and my 2013 modules to the 2015 manufactured version, that I got meta-data AND the callers name to display on my nav screen after a phone call.
Yeah it sucks to sink hundreds into a new module; but it's the only fix unless I hear differently from someone else here on the forum, and I haven't. Good luck!
-diggscreed
ananmatai 10-29-2017 03:58 AM
i HAVE 2010 MAZDA 6 WITH BOSE DISPLAY SYSTEM AND I ALREADY GOT
1, FACTORY NAVIGATION
2, DVD DISC
3, METRA ADAPTER FOR RADIO
4,GPS ANTENA
CAN YOU PLEASE TELL ME WHAT ELSE I WILL NEED TO MAKE SURE ALL THE FUTURES WILL WORK BEFORE I START OPEN THE UNIT ?
AND HOW ABOUT THE CONNECTION HARNESSES? i KNOW THE POWER AND THE METRA ADAPTER OK AND THE OTHER ONE I THINK FOR AUX JACK IS IT WORKING ?
THANK YOU.
