Where to run 4 gauge wire to the battery throught the firewall in a 2005 mazda 6? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 8 (permalink) Old 10-04-2015, 02:13 AM Thread Starter
im trying to install an amp in my mazda however i am having trouble getting the power cable throught the firewall. as i cant get it throught the main wiring loom without pulling out the whole dash because the blower unit is covering it (right hand drive).i just wanted to know if there is another location i can runt he wire through?
pyro55555 is offline
post #2 of 8 (permalink) Old 12-09-2015, 11:40 AM
You can run it through the gromount under the drivers side. Theres wire already going through there. I fit 0 gauge
cocoleveo7686 is offline
post #3 of 8 (permalink) Old 12-16-2015, 01:25 PM
MonoxideChild's Avatar
Quoted: 44 Post(s)
Groans: 66
iTrader: 2 reviews
Yup, Same here, running 0 gauge through the factory grommet on the left had side.
MonoxideChild is offline
post #4 of 8 (permalink) Old 12-21-2015, 04:15 AM
Quoted: 19 Post(s)
There's also one more towards the center of the firewall, depending on where you want to mount stuff.
thzpcs is offline
post #5 of 8 (permalink) Old 02-13-2016, 06:07 PM
The grommet under the driver side worked best for me, I've owned two mazda 6's and both i wired theough that grommet and through the fender
grobe is offline
post #6 of 8 (permalink) Old 03-14-2016, 05:55 PM
ekah's Avatar
Where did you guys ground the wire? I need help with that
ekah is offline
post #7 of 8 (permalink) Old 03-15-2016, 11:55 AM
ctg162's Avatar
Quoted: 10 Post(s)
The toughest part about the grommet that the main loom goes through is (at least on the 3.0) is getting it up through to the battery. I recommend an extra set of eyes to help you find it coming through the firewall, but if you want to screw around with trying to get it to pop through, more power to you. With persistence, and some lube, you'll get it.
That depends on where you're putting the amp. If you're putting it in the trunk, lift up the liner and ground it to the floor. There isn't anything under it, the closer you get to the spare tire well. Be careful if you're going to try to put it under the rear seats, you'll be close to the gas tank there.
Chris
Silver 2003 Mazda 6 3.0L V6
Geek Squad AutoTech
ctg162 is offline
post #8 of 8 (permalink) Old 05-09-2016, 12:00 AM
Drivers side tech flexed stinger 0 gauge
Joshq is offline
