50K Fluid Change - so easy! - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 1Likes
post #11 of 18 (permalink) Old 06-09-2017, 02:53 PM
Quoted: 9 Post(s)
Originally Posted by BrianU View Post
A couple of things to consider:
More than 10 years ago Honda adopted the 3x3 fluid change which basically was designed to dump three quarts, fill, run the trans through the gears, dump, fill repeat two more times.
How did you dump only three quarts?
2014 Mazda 6 GT
6-speed AT, 107k miles and counting
Weatherford, OK
jsouth is offline
post #12 of 18 (permalink) Old 06-09-2017, 05:37 PM
Quoted: 87 Post(s)
That's what comes out. The torque converter remains full and there is still some fluid in the transmission which is why Honda specs the 3x3 without power flush.
BrianU is offline
The Following User Says Thank You to BrianU For This Useful Post:
jsouth (06-12-2017)
post #13 of 18 (permalink) Old 06-09-2017, 09:50 PM
Quoted: 12 Post(s)
Originally Posted by eyedocorlando View Post
w1000i, Yes this is a partial fluid change. I performed that exact procedure from the serviced manual. I only got 3.4 quarts out but the transmission holds more in the torque converter and inside the valve body. Nobody recommends a flush anymore, but fairly regular partial drain/fill procedures done will keep the fluid contamination low and the fluid life and additives up.
In all seriousness though the fluid I drained out looked like dark tea, smelled not so fresh, and afterwards the transmission is far smoother on downshifts and when cold shifting in the morning than before. I will continue to make this part of my 30K ritual, it's very easy and worth it.
Considering this, it makes me wonder if I should do other things early. 60K coolant? 60K Plugs?
thanks for your replay, one more question > did you change the oil while the car is hot or you wait and how much you wait ?
w1000i is offline
post #14 of 18 (permalink) Old 06-13-2017, 02:31 PM
Quoted: 9 Post(s)
For those who have done this ATF drain/refill (not quite a change):
Did you have the car level on four jackstands or just the front on ramps (as I do for the oil change)? It will probably be obvious which would be better when I find the location of the drain plug, but I thought I'd ask before doing the work.
2014 Mazda 6 GT
Weatherford, OK
jsouth is offline
post #15 of 18 (permalink) Old 06-13-2017, 05:30 PM
Nostalgic Hero's Avatar
Quoted: 25 Post(s)
I would recommend anyone attempting to do this also change the tranny filter at least every 60k intervals. There's a giant magnet sitting inside of the trans oil pan that collects metal particles that should be cleaned also. The most tedious part was cleaning/removing the old silicone. It would be helpful to have 1k grit sandpaper, atv gasket maker, and silicone remover.
Sent from my iPad using Tapatalk
Nostalgic Hero is offline
post #16 of 18 (permalink) Old 06-13-2017, 05:49 PM
Quoted: 25 Post(s)
You will have to remove the whole plastic dust cover underneath the car to access the drain bolt. Probably Better to have the car leveled on all four. I kind of took a shorter route and had driver side supported on jack stand enough for me to work underneath the car. However once I began to drain the oil I ended up lowering the driver side to keep the car leveled.
post #17 of 18 (permalink) Old 09-18-2018, 04:00 AM
Quoted: 12 Post(s)
@Nostalgic Hero
Do have pictures or know of a video showing how to do that on a newer model Mazda6 please?
Thanks
tempdownload is offline
post #18 of 18 (permalink) Old 07-04-2019, 03:05 PM
John R. Santos's Avatar
Will refer back to this in a few months - good info, thanks!
John R. Santos is offline
