Transmission Service - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 5Likes
post #1 of 67 (permalink) Old 06-05-2015, 07:52 PM Thread Starter
Quoted: 35 Post(s)
Looking over the owners manual there is no listing for frequency of transmission fluid replacement service. Can it be that it needs NO service?
valleyguy is offline
post #2 of 67 (permalink) Old 06-05-2015, 08:00 PM
Quoted: 22 Post(s)
They claim that it's a "sealed" transmission not requiring service.
Sure, it might be lifetime fluid- where the lifetime of the vehicle is 5 years / 60k mi, whichever comes first.
I plan on changing mine at some interval I haven't yet determined. It can be done and there is a fill hole with a dipstick built into it.
'14 Mazda6 Touring/Tech, Soul Red/Sand
amd20x6 is offline
post #3 of 67 (permalink) Old 06-06-2015, 01:48 PM
Quoted: 143 Post(s)
Groaned at 6 Times in 6 Posts
Need more information
First of all we need to know what car you have. The older Mazda's auto transmissions required changing every 30k miles. The oils they use now are better , so probably will last longer. The best thing is to call Mazda and ask, that way you will get a straight answer. Thanks
Oldvet is offline
post #4 of 67 (permalink) Old 06-08-2015, 12:13 PM Thread Starter
Quoted: 35 Post(s)
My Mazda 6 is a new 2016.
post #5 of 67 (permalink) Old 06-09-2015, 12:55 AM
eyedocorlando's Avatar
Quoted: 91 Post(s)
Groaned at 5 Times in 3 Posts
Even though this has been discussed before, I'll go ahead and answer. There is a drain bolt on the transmission and it takes about 3.5-5qts of fluid if you drain it. You refill the transmission through the bolted in dipstick tube. Mazda does not formally recommend servicing the fluid, and they explicitly state do not flush the transmission in their service manual. Some people have changed the fluid to little effect .
eyedocorlando is offline
post #6 of 67 (permalink) Old 06-09-2015, 01:01 PM Thread Starter
Quoted: 35 Post(s)
Thanks for that info.
Seems odd to me that the 2016 6 manual does not specify ANY transmission service, yet the dealer offers it.
Guess I'm old school, I'll replace fluid at 40k to 50k, as I plan on keeping the car for quite awhile.
post #7 of 67 (permalink) Old 11-11-2015, 11:15 AM
I did a drain and fill at 25K. The factory juice is a green color, but the tranny fluid came out a weird brown color. I'm pretty easy on the car and don't abuse the tranny so I think it's normal. Didn't notice any performance difference, but since it's an easy task I'll probably do it every 25K-30K as I plan to keep my baby for a while.
2014 Mazda 6, Corksport RSB, Tannabe springs, AutoExe strut bar, Racing Beat Exhaust, Raybestos EHT pads
Lowered6 is offline
The Following User Says Thank You to Lowered6 For This Useful Post:
eyedocorlando (12-01-2015)
post #8 of 67 (permalink) Old 02-25-2016, 11:12 PM
Hi folks, newb mazda owner here. I used to work in a transmission shop. I honestly believe in changing your tranny fluid every 30,000 miles. That being said, I just bought a 2014 mazda 6 with 68,000 miles on it. I asked the dealership i bought it from to do a transmission flush and change the filter. They told me not necessary until 100,000 miles and even then its just inspection. I told them sorry, I want to flush the fluid and change the filter. Local dealership said there is no filter to change. I showed them the part number for a filter and went to a different dealership. 2nd dealership called in the shop foreman to talk with me. I asked him how often he changed his fluid. He said he didnt drive a mazda but did his every 30,000 just like me. He said there is no way to connect the flush machine to the skyactive tranny to do a catalytic converter flush so all they could do was drop the pan install a new filter and run the 4 quarts through which only removes about half the old fluid. I would have to run it for an hour or so and drain and repeat to get more of the converter fluid out. I caught the shop foreman in the break room and slipped him a 20$. When he gave me the car back he said he dug up about 3 more quarts in the shop and ran it through so if i believe him i should be good to go for another 60,000 between what i believe and the factory does. The mazda tranny fluid is blue and expensive. Its a non maintenance item because they last past the warranty but just barely. If you plan on keeping your car and driving the wheels off it like i do mine change the blue stuff and drop the pan, do the filter and do more than the single flush. My opinion fwiw.
Heres the scary part. You could ask for the same thing but your local stealership may stroke you and not bother to drop the pan and put in the filter, but just charge you for it thinking your crazy for asking for it. Maybe asking for the old filter back would help. Reinforcing what i just posted. The fluid is not supposed to be green or brown. Its supposed to be blue. Mine is now.
ArmoldasBak likes this.
wheredoesthisgo is offline
post #9 of 67 (permalink) Old 08-11-2016, 08:52 AM
I have a 2015 6 at 60k I'm going to look into this thanks for the info
Germs is offline
post #10 of 67 (permalink) Old 08-11-2016, 09:48 AM
jcme0557's Avatar
Quoted: 198 Post(s)
If it was my car, I'd change the ATF at 50-60k.
Car makers have been removing stuff like transmission fluid or brake fluid from lists of "scheduled" or "recommended" maintenance for years to show "lower cost of ownership."
Probably works for the first owner on a 2-year lease...but not the second or third owner.
jcme0557 is offline
