HUD Height Adjustment - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 10 (permalink) Old 05-23-2019, 11:31 AM Thread Starter
knsaber's Avatar
Quoted: 36 Post(s)
Has anyone had their HUD start up way too high or way too low randomly (reset button doesn't help)? Eventually the HUD resets back to normal height after a drive or two. I never change the settings (set to middle), and even the dealer couldn't figure out the reason, they just accuse me my seat set too high or low.
2016 Mazda6 Grand Touring w/Tech Pkg
knsaber is offline
post #2 of 10 (permalink) Old 05-23-2019, 09:55 PM
GerryB's Avatar
Quoted: 340 Post(s)
I had this happen a couple of times in my 3. Never did figure it out.
Sent from my SM-G960U using Tapatalk
GerryB is online now
post #3 of 10 (permalink) Old 05-23-2019, 11:03 PM
Caliche's Avatar
Quoted: 97 Post(s)
Yes, this is very annoying. On my 2016 Mazda6 I have to adjust the HUD down at almost every start-up because it displays too high, even though it is set at ‘0’. I have to turn it down into the negative numbers and back to the ‘0’ position to center it, but if I turn it up into the positive numbers and back to ‘0’, it does not go back to center. Weird and annoying.
Caliche is offline
post #4 of 10 (permalink) Old 05-24-2019, 01:34 AM
idrive's Avatar
Quoted: 295 Post(s)
Groans: 6
Have you tried - starting the car, adjusting the HUD where you want it and then program (save/program) your seat position with the memory button. #1 or #2 and or program the fob.
When you unlock the car with the fob or the button on the door handle the hud should return to where it was when you programed the fob or button.
Hopefully that made sense...
Build Thread:
idrive is offline
post #5 of 10 (permalink) Old 05-24-2019, 04:50 AM
Caliche's Avatar
Quoted: 97 Post(s)
That made total sense and I’m gonna try it, though I have had my seat position memorized on button #1 for a while. I never associated the two nor knew that unlocking the car with the fob vs. the door button made a difference, if I’m understanding you correctly. Thanks!
Caliche is offline
post #6 of 10 (permalink) Old 05-30-2019, 10:51 AM
mental's Avatar
My 2017.5 Mazda6 HUD ended up being really buggy after the Mazda Connect OS crashed one time. Was still under warranty, so the dealer updated to the latest version, and I haven't had any problems since (more details about that here: https://forum.mazda6club.com/5036648-post7.html)
2017.5 Mazda6 GT
mental is offline
post #7 of 10 (permalink) Old 06-06-2019, 01:08 AM Thread Starter
knsaber's Avatar
Quoted: 36 Post(s)
Thank you, I also had no idea the key fob memorized the seat position. Are you sure the Mazda6 does this? When I press Set, then #1 , I hear a single beep. When I press Set, then press the key unlock button, nothing happens and the SET beeps twice from timing out.
knsaber is offline
post #8 of 10 (permalink) Old 06-06-2019, 06:11 AM
dcoulombe's Avatar
Quoted: 37 Post(s)
Here's how it works :
https://www.mazdausa.com/static/manu...mory&hw=Memory
It can be a little bit tricky to do as you have only 5 seconds to press the button.
Once setup, change the position of the seat, exit the car, and unlock the car. The seat will change back to your set position.
dcoulombe is online now
post #9 of 10 (permalink) Old 06-06-2019, 08:59 AM Thread Starter
knsaber's Avatar
Quoted: 36 Post(s)
I'm 99.99% sure this key fob feature isn't in my 2016 Mazda6 Grand Touring. It just times out after 5 seconds when I try to press the unlock button on the fob.
knsaber is offline
post #10 of 10 (permalink) Old 06-06-2019, 10:59 AM
dcoulombe's Avatar
Quoted: 37 Post(s)
Here's the link for the 2016 :
https://www.mazdausa.com/static/manu.../03010200.html
Check if there's some difference.
Love how they write that is for "some models"... Clear as mud.
Similar Threads
Headlight Adjustment 2005-2007 JimK1961 Electrical / HVAC 21 07-29-2016 07:56 PM
DIY: Clutch pedal adjustment Test_Drive Engine / Suspension / Drivetrain 36 01-23-2014 11:23 PM
Just ordered BC Racing Coilovers malhavoc101 Speed6 Suspension/Chassis 225 09-16-2009 07:18 PM
How to adjust your headlights deedub35 Electrical / HVAC 6 07-26-2007 02:08 PM
Two adjustments and one modification today deedub35 Mazda6 (Atenza) 0 01-29-2005 05:54 PM
