Auto Transmission Oil Capacity - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 3Likes
post #1 of 12 (permalink) Old 04-02-2019, 10:15 PM Thread Starter
deepwater6's Avatar
Question Auto Transmission Oil Capacity
I thought I'd double check to see if the system holds 8.2 quarts of tranny oil as it seems quite a bit. Has anyone changed their own automatic transmission oil yet and does 8.2 quarts seem correct?
Thanks for your replies.
deepwater6 is offline
post #2 of 12 (permalink) Old 04-03-2019, 09:54 PM
PeteGT6's Avatar
Quoted: 7 Post(s)
I have a 2015 6 and just did a drain, drop pan, replace filter and refill. I measured 5.5 quarts coming out and that’s what I put back in. Checked it while running and level was perfect.
deepwater6 and cutepoison like this.
PeteGT6 is offline
The Following User Says Thank You to PeteGT6 For This Useful Post:
deepwater6 (04-06-2019)
post #3 of 12 (permalink) Old 04-06-2019, 03:19 AM Thread Starter
deepwater6's Avatar
Thanks for your reply!
post #4 of 12 (permalink) Old 04-11-2019, 02:37 PM
Quoted: 123 Post(s)
Im about to do this myself, about 60K miles and already on jacks for tire rotation and oil change. Are you using Mazda branded tranny oil? Ive been looking for an alternative.
I know they claim you have to use theirs...blah, blah, blah, they all say that and its bullshit for the most part. There are other fluids claiming compatibility and I been using valvoline max life multi vehicle ATF in other vehicles with good results. I think they claim its compatible with just about everything
mach1219 is online now
post #5 of 12 (permalink) Old 04-11-2019, 02:52 PM
Cdn17Sport6MT's Avatar
Quoted: 148 Post(s)
In some circumstances the slipperiness of the fluid does count a lot, and while there may be several commercially available fluids out there that could work, you may be taking a chance with them.
And also, there are some A/T's out there that are really, really fussy with regards to fluid and will not tolerate any variance in that regard.
Cdn17Sport6MT
Vancouver, BC Canada
Cdn17Sport6MT is online now
post #6 of 12 (permalink) Old 04-11-2019, 02:58 PM
Quoted: 123 Post(s)
I think ill give it a go. This tranny has been around for awhile and used in Ford Fusions from way back, although its been updated. I just cant stomach dealer prices for trans fluid.
post #7 of 12 (permalink) Old 04-16-2019, 05:30 PM
Quoted: 123 Post(s)
just thought Id share, glad I changed fluid when I did. Car has 58,120 miles, I wasnt expecting fluid to be as dirty as it was or the amount of gunk in the pan and on magnet. Ive changed ATF in other vehicles with many more miles on them and the fluid and pan were much cleaner than this. So I would suggest if anybody wants to keep their M6 long term, ATF fluid change at 60k mile intervals definitely a worthwhile task.
Cdn17Sport6MT likes this.
post #8 of 12 (permalink) Old 04-17-2019, 01:32 PM
PeteGT6's Avatar
Quoted: 7 Post(s)
I wish I changed mine at 40 or 50k instead of when I did at 80k. Just like you found, I had a lot of metal particles on the magnet and the fluid was in rough shape. I used atf multi vehicle max life and have had no issues to date. I have put about 3k miles since the change. I’m with you, I can’t see paying the oem prices.
PeteGT6 is offline
post #9 of 12 (permalink) Old 05-14-2019, 05:30 PM
johnnymg's Avatar
Quoted: 12 Post(s)
I just did a 'service' on my 2014 Mazda 6 transaxle (@65.5 K miles). With the car level I got just under 4 quarts drained from the pan. The old ATF looked VERY clean so I didn't bother with a filter change. I refilled the transaxle with just under 4 quarts of the very spendy Mazda ATF and then ran the engine for a good 5 minutes shifting from drive to reverse. I then drained the ATF again and refilled as before. I used an infrared temperature tool to make sure the ATF level was checked at ~120 degrees F when idling in park.
I got the Mazda ATF from Med Center Mazda. Part # is 0000-FZ-113E-01 and it's currently $11.50. You should be able to get this oil at your local Mazda dealer.
johnnymg is offline
post #10 of 12 (permalink) Old 05-14-2019, 08:00 PM
Quoted: 123 Post(s)
I have a 2015 6 and just did a drain, drop pan, replace filter and refill. I measured 5.5 quarts coming out and thatís what I put back in. Checked it while running and level was perfect.
I did similar, but didnt measure what came out, just put 5.5 q back in. It ended up on the high side, but im not going to worry about it. To drain some would be easy since the pan has a plug in case anyone else ends up in this predicament. make sure you warm it up and shift through all the gears before taking your dipstick reading
Similar Threads
No start after engine swap cardana24 2.3L I-4 25 02-26-2019 03:05 AM
About to change the transmission on 2004 Mazda6 4-speed auto J-Rod ATX Transmission Discussion 18 06-17-2014 07:31 AM
Long- 2006 3L 6-speed auto, Mercon V in transmission, need technical help please. standard ATX Transmission Discussion 3 03-17-2012 05:44 PM
Down shifting with auto transmission birdmfc ATX Transmission Discussion 7 10-16-2009 03:46 PM
Gated Shifter with Manual Mode for Auto. Transmission neoanderson2002 Engine / Drivetrain 12 10-24-2002 04:46 PM
