Auto Transmission Oil Capacity - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 3Likes
post #11 of 12 (permalink) Old 05-14-2019, 08:02 PM
Quoted: 123 Post(s)
Originally Posted by PeteGT6 View Post
I wish I changed mine at 40 or 50k instead of when I did at 80k. Just like you found, I had a lot of metal particles on the magnet and the fluid was in rough shape. I used atf multi vehicle max life and have had no issues to date. I have put about 3k miles since the change. Iím with you, I canít see paying the oem prices.
Yeah, the best price I could find was $17 a jug at walmart, so thats like $4.25 per quart, fairly reasonable these days
mach1219 is offline
post #12 of 12 (permalink) Old 05-14-2019, 08:06 PM
Quoted: 123 Post(s)
Originally Posted by johnnymg View Post
I just did a 'service' on my 2014 Mazda 6 transaxle (@65.5 K miles). With the car level I got just under 4 quarts drained from the pan. The old ATF looked VERY clean so I didn't bother with a filter change. I refilled the transaxle with just under 4 quarts of the very spendy Mazda ATF and then ran the engine for a good 5 minutes shifting from drive to reverse. I then drained the ATF again and refilled as before. I used an infrared temperature tool to make sure the ATF level was checked at ~120 degrees F when idling in park.
I got the Mazda ATF from Med Center Mazda. Part # is 0000-FZ-113E-01 and it's currently $11.50. You should be able to get this oil at your local Mazda dealer.
Did u drop the pan and clean it? Thats where all the nasty stuff settles. Even if you remove the filter and reuse it, just removing it allows probably another half quart or more to drain out.
mach1219 is offline
Similar Threads
No start after engine swap cardana24 2.3L I-4 25 02-26-2019 03:05 AM
About to change the transmission on 2004 Mazda6 4-speed auto J-Rod ATX Transmission Discussion 18 06-17-2014 07:31 AM
Long- 2006 3L 6-speed auto, Mercon V in transmission, need technical help please. standard ATX Transmission Discussion 3 03-17-2012 05:44 PM
Down shifting with auto transmission birdmfc ATX Transmission Discussion 7 10-16-2009 03:46 PM
Gated Shifter with Manual Mode for Auto. Transmission neoanderson2002 Engine / Drivetrain 12 10-24-2002 04:46 PM
