Oxygen Sensor P0171 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 11 (permalink) Old 02-20-2019, 06:23 AM Thread Starter
Quoted: 8 Post(s)
Oxygen Sensor P0171
Just a lesson learned post in the hope it will save someone some hassle. 2014 touring m/t has 174k+ miles on it and I just had to replace the upstream o2 sensor. Before that I mistakenly replaced the pcv valve. Apparently the vacuum pull on these is lower than I'm familiar with for older vehicles. Code was a P0171 and came with a rough idle (actually stalled itself a few times) and hesitations and surges anywhere from idle to about 3000rpm. Above that it was more cyclical. As in if trying to cruise at 70 mph it would do more 65-70-65-70...If it happens to you unhook the 02 Sensor and go for a drive. If it fixes the issues the new sensor is what you need. NTK 24369 appears to be same as oem with same length, color, plug, and everything. Actually got mine from autozone for $125 because they could get it in 2 days. Hope this helps somebody!
Sent from my ONEPLUS A5000 using Tapatalk
bigbubba4421 is offline
The Following User Says Thank You to bigbubba4421 For This Useful Post:
DrFeelGood (02-21-2019)
post #2 of 11 (permalink) Old 02-20-2019, 06:59 PM
Quoted: 107 Post(s)
Thx for sharing. As for your car with 174k miles: impressive! Can you recount to us any other prbs encountered?
Cdn17Sport6MT
Vancouver, BC Canada
Cdn17Sport6MT is online now
post #3 of 11 (permalink) Old 02-21-2019, 03:16 PM Thread Starter
Quoted: 8 Post(s)
Besides regular maintenance(engine oil, trans oil, brakes, plugs 100k, coolant flush 105k). I did the belts, tensioner and water pump around 130kish because the accessory belt snapped not the water pump belt but "while you're in there. " Replaced front wheel bearings (Probably because I drive on construction sites for work. Probably not a big wear item for regular commuters. )
post #4 of 11 (permalink) Old 02-21-2019, 03:26 PM
Quoted: 12 Post(s)
driving on construction sites, did you replace the structs or any suspension components? steering components? any weird noise when you turning the wheel?
lltfly is offline
post #5 of 11 (permalink) Old 02-21-2019, 07:07 PM Thread Starter
Quoted: 8 Post(s)
Knock on wood but no. No struts, shocks, control arms, ball joints, etc. Probably not as quiet as the day I bought it but nothing has shown enough play to warrant replacement.
post #6 of 11 (permalink) Old 02-25-2019, 02:54 PM
Quoted: 12 Post(s)
Sorry about too many questions.
Do you have any issue on carbon buildup? or have you done any maintenance against carbon on intake valve?
lltfly is offline
post #7 of 11 (permalink) Old 02-25-2019, 08:15 PM Thread Starter
Quoted: 8 Post(s)
Lol. It's fine. I realize I'm a bit of a Guinea pig with this engine. Honestly, aside from a gas treatment every now and then(amsoil) (definitely not with any regularity) I've done nothing special. Maybe b every 30k on average. If there is buildup in there it's not affecting power enough for me to notice. I haven't been in there to check officially. If it's something that I've done that is contributing to my success my guess would be amsoil signature oil with their filter? 10k-12k change intervals. I also forgot to mention in my first maintenance that I did have the entire brake system bled at 100k as well and intend to again at 200k.
post #8 of 11 (permalink) Old 02-25-2019, 11:49 PM
Archerfish's Avatar
Quoted: 87 Post(s)
Wow! Close to 200,000 miles.
If I may stray from the topic, how many times have you changed the transmission oil?
Archerfish is offline
post #9 of 11 (permalink) Old 02-26-2019, 02:18 PM
Quoted: 12 Post(s)
that is good question I guess. since Mazda says life time transmission fluid, there are not quite a lot of people change it. but I own a Acura TL as well, I change transmission fluid every 20k miles. but not filter change for it.
I plan to do the transmission fluid for my 6 as well, but I am not sure if I need to change the filter, that is in the pan
lltfly is offline
post #10 of 11 (permalink) Old 02-26-2019, 03:43 PM Thread Starter
Quoted: 8 Post(s)
Only once at 50k. The whole quart with red line. Manual trans here though.
Similar Threads
Oxygen sensor location question Jooleeus 3.0L V6 30 09-17-2016 02:14 AM
Oxygen O2 Sensors chikoo 3.0L V6 3 06-07-2014 01:19 PM
oxygen sensor wiring diagram needed kerak Electrical / HVAC 2 03-15-2010 10:58 PM
AutoEnginuity DataLogger... Wiggum Mazdaspeed6 48 10-09-2006 04:34 PM
For those of you with the AutoEnginuity unit... Wiggum Mazdaspeed6 3 06-29-2006 05:26 PM
