Cruise control does not turn off!! HAZARD!! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 1Likes
  • 1 Post By GerryB
post #1 of 9 (permalink) Old 02-03-2019, 12:00 AM Thread Starter
Quoted: 29 Post(s)
Does anyone know WTF is up with my cruise control on my 2017 Mazda6??? I can't turn it off unless i hit the brakes and even then it's not fully off. The cruise control icon remains (in white not green coloured) meaning it's ready to activate again. When I hit the "off/can" button it decreases my speed when pressed and when i hit "set/-" it increases my speed. The "on" and "res/+" buttons do nothing.
I find this to be quite the safety hazard. Is this something that should be covered under warranty and even if it's not under warranty since it's a hazard??
I have a video of this in action but i don't know how to upload it.
stovetop is offline
post #2 of 9 (permalink) Old 02-03-2019, 08:31 AM
ocramida's Avatar
Quoted: 291 Post(s)
Just go and have it checked. Probably defective switch or electronic module. This is warranty is for.
ocramida is offline
post #3 of 9 (permalink) Old 02-03-2019, 08:48 AM
dcoulombe's Avatar
Quoted: 28 Post(s)
Here's how it's supposed to work. If yours don't act like it's supposed to, you need to have it checked.
https://www.mazdausa.com/static/manu.../05100101.html
dcoulombe is online now
post #4 of 9 (permalink) Old 02-03-2019, 10:10 AM
GerryB's Avatar
Quoted: 338 Post(s)
Have you read the manual for proper use and function?
93blkongreenpro likes this.
GerryB is offline
post #5 of 9 (permalink) Old 04-20-2019, 12:30 PM
Quoted: 8 Post(s)
Sounds like there might be a programming issue. I know in my 2016 it will stay active even after turning the car off then on again until I tell it to turn off. The other buttons should work though.
Sp1d3y is offline
post #6 of 9 (permalink) Old 04-23-2019, 02:09 PM
Quoted: 70 Post(s)
From time to time, my CC is Off but I have no recollection of turning it Off. It does not turn off while actively using it. It turns off either after the car is shut off or between cancel and resume events. I don't know if it's the car or if I'm accidentally tapping the Off button.
2017 Mazda 6 Touring manual
LeMansteve is offline
post #7 of 9 (permalink) Old 04-23-2019, 02:34 PM
tickerguy's Avatar
Quoted: 906 Post(s)
Groaned at 7 Times in 7 Posts
Yep -- that's how it's supposed to work.
Unless you hit the OFF button the light on the dash will be amber or white in color, meaning "available but not engaged."
This is "sticky" across ignition off/on as well.
Incidentally this is exactly how my VW Jetta works, except the "arm" switch (on/off) is a physical switch on the stalk.
tickerguy is offline
Byakuya (04-23-2019)
post #8 of 9 (permalink) Old 04-23-2019, 02:39 PM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2876 Post(s)
Correct on all accounts.
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
post #9 of 9 (permalink) Old 04-23-2019, 02:47 PM
tickerguy's Avatar
Quoted: 906 Post(s)
BTW one of the EXTREMELY annoying differences between European and Asian-sourced vehicles is that European vehicles tend to have the audio controls on one side and Asian ones on the other. This means if you drive BOTH you'll often hit what you THINK is the "speed up/down" button for the cruise control and actually get the radio volume -- and vice-versa.
Similar Threads
Fit Cruise Control on a 2.3L AWD which doesn't have one ? D3xmeister 1st-Gen 2 02-29-2016 12:06 PM
245/40r18 fit mazda 6i? Cruise control problem duercos Newbie Section 0 01-31-2016 12:41 AM
Top 10 Affordable Cars With Adaptive Cruise Control AutoGuide.com Frontpage News 0 10-01-2014 12:02 PM
Cruise Control too much transmission shifting markregel Mazda6 (Atenza) 1 01-16-2012 08:54 PM
Mazda6/MazdaSpeed6 DTC's y2kc0wb0y Engine / Drivetrain 1 01-10-2009 09:42 AM
