Retrofit possibilities for 2017 halogens - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 2Likes
post #21 of 27 (permalink) Old 11-28-2018, 07:37 PM
Quoted: 227 Post(s)
Originally Posted by Mazda6Suspension View Post
lmao there is nothing wrong with them. I'm pretty sure nothing has happened to your headlights. You're just "bored" of them and the fact that they look stock, you want to be "different" that's why you modded your car very differently from most cars. It doesn't mean these headlights are bad and $500 for headlights with hid projector and nice led drl is a good price
You just want those out of the ordinary "unique" everything, which is why you want to retrofit.
Nah, light output sucks. Cheap projector lenses. Zero clear cut off lines combined with hot spots. Typical Chinese products with zero QC checks.
calcaneous is online now
post #22 of 27 (permalink) Old 11-28-2018, 07:49 PM
Mazda6Suspension's Avatar
Quoted: 546 Post(s)
Groaned at 46 Times in 39 Posts
were you expecting lexus quality projectors? lol I knew very well that these projector lenses weren't going to be great. I never or rarely drive at night, but I have tried them at night and they are not too bad. I mainly bought them for their look and the led drl. You can "retrofit" them also, open them, change the projectors and shit, keep the stock headlights look, use osram hid bulbs, can be done but I can't be bothered with that shit
This is good enough for me, but live and learn, next time I buy a car, it will be one that comes with oem hid or led headlights and not halogen ones like the 2014-2015 touring and sport
cause if you have halogen projectors, then you stuck pursuing the unattainable, people get hid kits on their halogen projectors, which looks like shit and yellow in comparison to real hid projectors, people like me bought aftermarket headlights with hid, but it still looks like shit in comparison to oem hid projectors like lexus and the such
people do retrofits and spends hundreds, if not thousands, but even then, it doesn't guarantee the quality will be as good as oem hid projector headlights, built by a huge companies with robots and perfect quality material, technology, etc
moral of the story, maybe is better to buy the higher trim than chasing ducks
Mazda6Suspension is offline
post #23 of 27 (permalink) Old 11-28-2018, 07:54 PM
Quoted: 227 Post(s)
Not Lexus quality but projectors shouldn’t have hot spots. That is a huge sign of crap manufacturing.
The stock halogens are way better then these.
post #24 of 27 (permalink) Old 11-28-2018, 08:06 PM
Quoted: 546 Post(s)
They may be better at projecting output, but they make hid bulbs look like shit. I had 4300k hid bulbs on the stock halogen projectors and they looked yellow, then I put 5000k bulbs and still yellow, just slightly less yellowish. These bulbs were decent from xenondepot. You could put bulbs from the beloved and overrated morimoto and they would still look as yellow. You can even put osram bulbs on there and they wouldn't look as advertised.
It was only when I put the 5000k bulbs on the chinese headlights that they actually look like real hid. Nothing changed, same hid kit and ballasts, but different headlights. You want everything, then you either spend a lot money on retrofit or buy a new car with real hid projector headlights.
Now here is another problem, you may do a retrofit with "quality" materials such Lexus projectors, osram bulbs and the such, which you can buy online, many retrofitters do this, rx350 projector is the most popular, this is cooland dandy, but just because you use similar materials used by oem manufacturers doesn't guarantee your retrofit will be as good as oem projector headlights like stock mazda 6 gt let alone a Lexus
All the headlights components from the smallest to largest plays a role in everything. You using some of the material (lexus projectos, similar bulbs used by oem, etc) doesn't guarantee it will be as good. First of all, most retrofitters are doing the retrofit on lower trim headlights of their car, which is inferior to the higher trim version of those same headlights in every aspect
Second, they will have to use an HID kit and unless you plan on buying a denso ballasts for your headlight, it will never even come close, morimoto, xenon depot? they're ok but trash in comparison to denso which is what oem manufacturers use in their cars
the ballast alone are probably the same cost of these chinese headlights lmao
and you better believe ballasts play a big role in headlights output and everything
moral of the story, buy the higher trim rather than chasing the impossible lol
post #25 of 27 (permalink) Old 11-28-2018, 08:13 PM
Quoted: 227 Post(s)
It was only when I put the 5000k bulbs on the chinese headlights that they actually look like real hid. You want everything, then you either spend a lot money on retrofit or buy a new car with real hid projector headlights.
Regardless of that wall of text I’m not bothering to read. These headlights should have never been sold. Hot spots are a no-no. It’s a shame because they look nicer off then on.
I didn’t even bother to hook up the “drl” lights to function as drl because knowing my luck so far with them, they’ll burn out within 2 months.
post #26 of 27 (permalink) Old 11-28-2018, 08:33 PM
Quoted: 546 Post(s)
what lol so basically you wasted $500 for nothing, you have no right to complain, you knew very well these headlights weren't going to be great, we both took a gamble on them, I'm satisfied because I wanted the dark headlights with the led drl. I rarely drive at night. And of course, you will "sell them" on here
What were you expecting for $500? The touring headlight are more expensive lol you know how much the stock GT headlights cost? Lexus headlights cost? in the thousands and thousands, the ballast used in these oem hid headlights is same price if not mo-re expensive than these chinese headlights and even touring headlights lmao that alone should tell you
you bought those CC headlights and they turned out to be shit, you payed how much? $400-500? and these were halogen and now you paid the same price for chinese HID PROJECTOR headlights and expect them to be any better than halogen headlights of the same price? lol
obviously retrofit is the only option to even come close to stock hid projector headlights, you may even surpass the stock mazda gt headlights if you are willing to spend all the money that it will be required
I can't be bothered with that shit, i'd rather have oem hid headlights than any retrofit but since I'm not stupid to get in debt for a new car when this one is paid off and looks decent, this chinese suckas will do just fine
lesson learned though, next car will be either a lexus or infiniti with hid ideally
post #27 of 27 (permalink) Old 11-28-2018, 09:06 PM
Quoted: 227 Post(s)
The c lights at least had a proper cut off. The output just sucked. The GT have bad output, hot spots, and a un-clear cut off. Thought that moving up the Chinese ladder from the c lights to these “GT” lights , which should have better projectors, there would be some improvements. But none, they got worse. Lesson learned.
I can probably get no name brand projectors for 20 bucks that will outperform these GT lights. The hot spots , which are crazy bad looking, just ruin the whole headlight. It’s basically high-beam spots.
—-O—- It should be a straight line.
I think the c lights were 300 shipped ? I couldn’t even bring myself to sell them , I ended up just throwing them out.
