LED Underglow install | wire routing - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 7Likes
post #1 of 12 (permalink) Old 10-08-2016, 03:41 AM Thread Starter
Quoted: 16 Post(s)
I apologize in advance if there is already a thread on this but I didn't see one for our 3rd gens. I bought an LED underglow kit (bars) that I would like to install under my 2015 mazda 6 touring. I have installed an under-dash led kit myself but have never installed underglow. Shops are asking anywhere from $150-$500 to install them but I want to do it myself. My biggest concern is that I'm not sure exactly how to lead the wires from the bottom of the car to inside the engine bay (where I have to mount the transponder near the battery/fuse box). Which way should I route the wires so that they don't come into or close to contact with moving parts, heat, etc. Also, if you guys have recommendations where exactly to mount the bars under the car so that when I jack up the car, the leds wont get crushed. Say what you want, yes they are ricey and tacky but I've loved them since I was a kid playing need for speed underground lol Any help would be much appreciated.
kufliclicks, soopa76 and txsv_2 like this.
zWaj is offline
post #2 of 12 (permalink) Old 04-14-2017, 07:26 AM
soopa76's Avatar
Quoted: 26 Post(s)
Bump!
soopa76 is offline
post #3 of 12 (permalink) Old 04-14-2017, 07:47 AM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2813 Post(s)
Hmmm, never even saw this post originally.
First: Check with your local/state regulations - As far as I'm aware, these are strictly prohibited in the vast majority of jurisdictions and will get you pulled over immediately.
For running the wires, your best bet is probably somewhere along the wheel well/fender liner. There's plenty of space behind all that plastic, and a few nice openings to the engine bay. Won't be super easy to get your hands up there, but taking the tire off and unclipping the liner will help a ton.
For mounting them, I'd say anywhere is appropriate so long as you still have a place to jack the car up. The easiest might be right alongside the metal juncture that's directly below your doors. If you put the strip on the inside (closer to center of car) of the juncture, you won't get any direct view of the LEDs from the side of the car, but they'll give off a ton of light directly under.
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
zWaj (04-17-2017)
post #4 of 12 (permalink) Old 04-14-2017, 07:57 AM
Zeffer's Avatar
Quoted: 171 Post(s)
Mount them towards the middle of the car, beyond your frame rails. IIRC there are some flat enough spots that will work. If they're strips, jacking up the car shouldn't hurt as long as they're away from the jackpoints. For routing the wires, I would run them into the mudguards, and up and over. Driver's side mudguard covers part of the undercarriage, so run them back there. Passenger is the same, but then tuck the wires up under the back of the engine bay, near the wipers. Mate everything together behind your battery/fuxebox/strut tower/etc. Piggyback off an always-lit fuse. If you want, you can run an auxiliary switch into the cabin through the OEM harness's grommet in the firewall. Mount the switch in the coinholder to the left of the wheel and you're set. If not, you can always just mount a switch under the engine bay for ease of install, but I would route it inside. You'll need a lot of wire. Easy peasy, and best of luck.
EDIT: Didn't realize Byakuya was posting at the same time I was! Glad we're on the same wavelength though.
Jacksonville, FL
Zeffer is offline
The Following 2 Users Say Thank You to Zeffer For This Useful Post:
Byakuya (04-14-2017), zWaj (04-17-2017)
post #5 of 12 (permalink) Old 04-14-2017, 12:24 PM
mendozahtc's Avatar
Quoted: 23 Post(s)
Looking to do this as a function with my puddle lights so it lights the under area of the car only when i open the door. If i get a chance soon ill get pictures up.
mendozahtc is offline
post #6 of 12 (permalink) Old 04-17-2017, 02:43 PM Thread Starter
Quoted: 16 Post(s)
Update: Thank you to those who replied. Haven't been on the forums for a while and actually did the install with a friend a few months ago myself (along with some help of a friend to zip tie the wires so they don't hang). I did exactly what @Zeffer and @Byakuya said and ran the wires through the mudguards but it was a real PITA to route and especially zip-tie them so they don't hang. If I were to do it again, I would go with a wireless setup (I think XKGlow makes one). Have had them for maybe 3-4 months and have had no issues with them so far.
Cops: I know people who have been pulled over for underglows before in MA but I think I've been lucky. I was pulled over a few weeks ago for speeding (warning) by a local cop and he didn't say anything about my exhaust (muffler delete - mad loud) or underglows on. I've been "trying" to drive with white underglows (to see if cops bother me) and have passed multiple cops anywhere from Worcester area in MA to Boston without issues. I can change the colors but I drive with white on because it doesn't attract as much attention that blue and red does (cops hate blue and red on regular cars and will give you sh*t for them - "impersonating a police officer" type of ticket). So far they haven't bothered me about it but its better not to risk it.
By the way, because the car has dual exhaust, I didn't mount the back strip, just makes it a bigger pain. This mod was well worth the 6+ hours I spent to install it!
zWaj is offline
post #7 of 12 (permalink) Old 04-17-2017, 06:51 PM
OCTOGONPC's Avatar
Quoted: 252 Post(s)
And where are the pics?
OCTOGONPC is offline
post #8 of 12 (permalink) Old 04-18-2017, 11:02 PM Thread Starter
Quoted: 16 Post(s)
Had so many pics on my old phone but legit cracked the whole screen few weeks ago. When I get it fixed I will upload more but here is one.
OCTOGONPC and kufliclicks like this.
zWaj is offline
The Following User Says Thank You to zWaj For This Useful Post:
OCTOGONPC (04-19-2017)
post #9 of 12 (permalink) Old 04-19-2017, 07:27 AM
OCTOGONPC's Avatar
Quoted: 252 Post(s)
Thumbs up One or Many...
- Niiiiice!!
Is your kit a one color or RGB kit?
What brand you buy (Link)?
post #10 of 12 (permalink) Old 04-19-2017, 08:51 AM
my95tsi's Avatar
Quoted: 260 Post(s)
Brian O'Connor approved!
OCTOGONPC and zWaj like this.
my95tsi is offline
