Infotainment touch screen while driving - Page 5 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 19Likes
post #41 of 56 (permalink) Old 02-14-2017, 07:15 PM
Sound's Avatar
Originally Posted by 14000 View Post
Well that sucks. I have to say, the infotainment system REALLY takes away from what is an otherwise very pleasant experience. Disappointing.
If you are tech savy and fairly comfortable with linux/computer apparently you can ssh into the car.
Example
Apparently all thats needed to disable the speed toggle is this
Code:
/jci/scripts/set_lvds_speed_restriction_config.sh disable
/jci/scripts/set_speed_restriction_config.sh disable
'16 Mazda 6 - iSport
Sound is offline
post #42 of 56 (permalink) Old 02-14-2017, 11:13 PM
Quoted: 24 Post(s)
So how does that work? Just download that code onto a USB and plug it into the USB drive in the car?
14000 is offline
post #43 of 56 (permalink) Old 02-15-2017, 08:43 AM
SVShootingStar's Avatar
Quoted: 68 Post(s)
Groans: 7
Can someone point me toward the thread about clipping a single wire on the 2014 to disable the nav lockout? I've been beating my head against the wall trying to find it.
SVShootingStar is offline
post #44 of 56 (permalink) Old 02-15-2017, 02:41 PM
Quoted: 32 Post(s)
This is the thread that I am aware of. This is for the Tom Tom nav in 2014-2015 6's.
http://forum.mazda6club.com/3rd-gen/...ml#post4232745
Current: 2016 CX-9 Grand Touring, 2014 Mazda 6 Touring, 2012 Mazda 3 Touring Sold: 2004 Mazda 6s V6 5-door
jskywalker is offline
The Following User Says Thank You to jskywalker For This Useful Post:
SVShootingStar (02-15-2017)
post #45 of 56 (permalink) Old 02-15-2017, 02:59 PM
Quoted: 68 Post(s)
Groans: 7
That's what I was looking for. Thanks!
post #46 of 56 (permalink) Old 02-16-2017, 08:14 AM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2886 Post(s)
LMK if it works for ya - definitely sick and tired of it at this point.
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
post #47 of 56 (permalink) Old 02-16-2017, 12:00 PM
Quoted: 68 Post(s)
Groans: 7
Gonna wait a bit until it warms up. Those plastic tabs used on the trim can be pretty brittle in the cold and tend to snap off. Will report back.
post #48 of 56 (permalink) Old 02-16-2017, 12:03 PM
Quoted: 32 Post(s)
I've been running with that mod in my 2014 Touring for well over a year. It works and there are no undesirable side effects. I highly recommend it for anyone with the Tom Tom system.
As stated in the other thread, I put a rocker switch in my glove box, so I can connect the wire or disconnect the wire with a flip of the switch. But honestly, I leave it disconnected 99% of the time. As long as you have some discipline to drive safely, it's not an issue.
post #49 of 56 (permalink) Old 02-20-2017, 12:26 PM
Quoted: 68 Post(s)
Groans: 7
Did the mod this morning. Less than an hour and everything seems to be working as it should.
post #50 of 56 (permalink) Old 02-26-2017, 01:08 PM
Quoted: 68 Post(s)
Groans: 7
...everything seems to be working as it should.
UPDATE - The speed sensitive volume control no longer works. Not a big issue for me.
