2nd Gen 3.7 waterpumps - longevity? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 1Likes
post #1 of 26 (permalink) Old 10-13-2016, 12:17 PM Thread Starter
dmperfection101's Avatar
Quoted: 7 Post(s)
- cross posted to 6Crew -
I've been searching for info on waterpump problems, longevity...any general issues I should be aware of. Info seems to be pretty scarce. My 6 has 104k miles. Other cars I've owned were timing belt engines. I've always been one to take preventative measures and replace timing belt and water pumps to avoid problems.
Now, I'm fully aware the 3.7 has a timing chain. However, after doing some reasearch and digging, the water pump on this 3.7 is buried in the engine and can be a very expensive replacement or cause serious engine damage if one fails.
Is the fact that I only find scarce info on waterpump failures supposed to be reassuring? Did Mazda (Ford) intend for the waterpump to be a lifetime component?
Sent from my SM-G925P using Tapatalk
dmperfection101 is offline
post #2 of 26 (permalink) Old 10-17-2016, 07:58 AM
Mz6GreyGhost's Avatar
Quoted: 795 Post(s)
I'm not sure if it's necessarily a "lifetime" component, but if you keep up on the coolant flushes, I doubt you'll have any issue with it.
The fact that there isn't much out info out there IMO is a good thing, since the only time you'll see any info/stories on it is if it fails.
Mz6GreyGhost is online now
post #3 of 26 (permalink) Old 10-23-2016, 02:57 AM Thread Starter
Quoted: 7 Post(s)
Well, it seems my nightmare has begun.
Today, driving on freeway, my '09 6s died. I coasted to shoulder. Pulled oil dipstick and it was all milk. Pulled off oil fill cap and it was coated cream.
Now, what to do.
post #4 of 26 (permalink) Old 10-24-2016, 08:01 AM
Quoted: 795 Post(s)
Oh boy...
Definitely keep us updated with what the mechanic says about this. I'm hoping it's nothing that's terminal.
post #5 of 26 (permalink) Old 02-17-2017, 07:52 PM Thread Starter
Quoted: 7 Post(s)
I'm back! After my sulking and self pitty stage, I ponied up the money to get my 6s GT fixed. Water pump was the issue. One water pump, new timing chains and guides, and sla shit load of labor money and she's back up and running.
post #6 of 26 (permalink) Old 02-18-2017, 03:28 AM
waughoo's Avatar
Quoted: 377 Post(s)
Another one saved! Why did you do the chain and guides?
waughoo is offline
post #7 of 26 (permalink) Old 02-18-2017, 08:35 AM
b1lk1's Avatar
Quoted: 282 Post(s)
Groans: 19
Waterpump is driven off the timing chain. Always change everything, especially when it has this kind of mileage, while you're in there.
b1lk1 is offline
post #8 of 26 (permalink) Old 02-18-2017, 08:56 AM Thread Starter
Quoted: 7 Post(s)
As b1lk1 said, best replace while there. When waterpump is replaced, it's recommended to replace chains and guides as well. I called around to a couple shops and dealers to get rough estimates on repair and they all said Mazda recommends timing chain replacement when replacing water pump.
post #9 of 26 (permalink) Old 02-18-2017, 12:16 PM
waughoo's Avatar
Quoted: 377 Post(s)
I didn't know it was driven by the timing chain. I'll have to look that up for my own education. I've not yet had a reason to look for my water pump since buying the car.
waughoo is offline
post #10 of 26 (permalink) Old 02-20-2017, 03:29 PM
Quoted: 795 Post(s)
It didn't take 4 months for someone to fix it, did it? If that's the case, I'm f*cked!
Knocking on 108K miles, and knocking on wood that my pump gets through the winter at least...
