New to me 05 Sportwagon is oily - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 1Likes
post #1 of 13 (permalink) Old 07-07-2019, 08:55 PM Thread Starter
Are there common points of failure with the gaskets, seals, boots etc? I haven't been able to spend a whole lot of time under the front to track down the leaks I just know that its messy underneath.
thaxman is offline
post #2 of 13 (permalink) Old 07-08-2019, 01:28 AM
Quoted: 14 Post(s)
Off the top of my head. Timing chain cover, oil pan and valve covers.
604mazda6 is offline
post #3 of 13 (permalink) Old 07-08-2019, 09:15 AM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2896 Post(s)
^^ What he said. Check your PCV valve/hose as well since those are prone to cracking/breaking and are a super easy fix.
Welcome to the forum!
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is online now
post #4 of 13 (permalink) Old 07-09-2019, 08:38 AM
I just picked up an 04 wagon and the valve covers were leaking badly. Particularly the front one. It was about a 4 hour job to pull, clean(this took the most time), reseal and replace them.
banzairx7 is online now
post #5 of 13 (permalink) Old 07-09-2019, 11:54 AM
Quoted: 451 Post(s)
Mine has been all timing cover until recently with the bank 1 valve cover. Rust protection.
Mozz-D
DrFeelGood is online now
post #6 of 13 (permalink) Old 07-20-2019, 11:30 PM Thread Starter
Timing cover....
Seems likely.
Also brings me to another question:
When pressing the throttle from idle, such as when starting out or even in neutral or park, I can hear a tapping, clicking, or mettalic throbbing that increases with the rpms but appears to quiet by 2K. IOW, I can only hear it from idle speed to 2K rpms, whether driving or stopped. I wonder if it is a loose timing chain, that rattles until up to speed.
thaxman is offline
post #7 of 13 (permalink) Old Yesterday, 09:03 AM
I've been playing whack a mole oil leak with my wagon for the last two weeks. I had a leaky front crank. It was the seal and the end of the crank needs to be sealed with silicone behind the crank bolt. Another source of leaking was my oil pressure sensor.
post #8 of 13 (permalink) Old Yesterday, 12:21 PM
Quoted: 451 Post(s)
Isn't this the front main seal? I don't think silicone alone will do it. Is that exactly what you said?
That one should be easy. Remember it is into aluminum so don't over tighten it.
Well done.
Show us some pics of the ride when you get a chance.
https://forum.mazda6club.com/picture...ur-photos.html
Mozz-D
post #9 of 13 (permalink) Old Yesterday, 01:02 PM
Quoted: 451 Post(s)
Timing cover....
Seems likely.
Can you include a video?
Mozz-D
post #10 of 13 (permalink) Old Yesterday, 11:20 PM Thread Starter
What are the hosting reqs for video here? I've actually never posted a video on any forum for any past or present car, so its all new.
thaxman is offline
