Daughter over-revved the motor!!! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 4 (permalink) Old 05-15-2019, 01:00 PM Thread Starter
Well, my 15yo daughter who just started driving on her permit got in the car to drive last night, mind you she has already driven a few times in this car and also once in the drivers ed car. She proceeded to start the car...with her foot ON the gas pedal...with it pushed to the FLOOR!!! And THEN held it there for at least 6-8 seconds while the motor screamed! And of course, I was screaming at her to get her foot off the gas!
The car seemed to drive ok at the time but later in the evening I went to pick up my younger daughter and drove it about 3 miles or so and stopped for a few minutes while I went in the store then came out and drove it about 5 minutes home and noticed a weird belt squeal and then noticed it was overheating! Mind you this car has not had one problem overheating since I bought it last year for my older daughter.
Without lifting the hood, I am guessing it has at least one blown head gasket and knowing the weakness of the timing chain I would say it is probably screwed as well!
Anyone else had an issue with over revving the motor?
Jeff
jmartin99 is offline
post #2 of 4 (permalink) Old 05-15-2019, 01:49 PM
DJ Raydiate's Avatar
Quoted: 84 Post(s)
I've bounced mine at the rev limiter and haven't had an issue. What year is the car? Without lifting the hood, why assume it's a head gasket. . Is it leaking fluid? White smoke out of the exhaust? Milky oil? The rev limiter is there to help keep the engine in safe rpms. I could understand if she set a block on the gas pedal and walked a way for a min or so.
1st, go open the hood and take a look. Check the oil and see if it looks milky.
2nd, look at the water pump belt to see if it looks more stretched than it should. If it's a 03-05 without the new style belt, look at the tensioner.
3rd, check all the hoses around the water pump. There is one right behind it that I've seen swollen due to oil leaks( mine and every v6 in scrap yard that I've seen)
4th, Check the exhaust for white smoke.
Ray.
2003 Mazda 6s
Brakemotive Drilled and slotted rotors, Modified eBay CAI, EGR reroute and optimized, TB coolant delete, Brake light mod, AWR Racing Lower dog bone, AWR Right engine mount, BIG 5 upgrade, Battery Relocated, Custom Busbars, Optima Red top, 2 12" Planet Audio BBD12, Rockville Audio 1400w 4chan amp, Rockville Audio 8000w sub amp, RX 8 seats, Custom LED side markers, Lower rear bumper lights and lots more to come!!!
DJ Raydiate is offline
post #3 of 4 (permalink) Old 05-15-2019, 01:56 PM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2876 Post(s)
I'm with him. The rev limiter is there to protect from these exact types of occurrences. She would have had to do it for a good 30+ seconds for it to start doing any type of damage.
Check your fluid levels, make sure the plastic-T connector isn't leaking, and everything DJ said. Report back with what you find.
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
post #4 of 4 (permalink) Old 05-15-2019, 02:56 PM
jman1200's Avatar
Quoted: 85 Post(s)
You mentioned a belt squeal. Not sure if the water pump is belt driven but that could be it. Your belt could be stretched or the over revving caused the water pump bearing to fail causing the belt to slip and/or also the pump to spin slower or be seized.
jman1200 is offline
Similar Threads
No start after engine swap cardana24 2.3L I-4 25 02-26-2019 03:05 AM
Zeffer's Product Review: Corksport Polyurethane Rear Motor Mount Zeffer Engine / Drivetrain 5 06-11-2018 09:22 AM
Motor Blown JDM motor install? jgulley1 1st-Gen 6 05-26-2016 08:00 AM
HVAC Blower Motor Noise dmnorris Electrical / HVAC 0 04-27-2013 12:59 AM
Moonroof not working - relay or motor? uniarmy Electrical / HVAC 0 05-22-2011 06:22 PM
