2006 wagon manual trans problem - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Old 03-28-2019, 11:02 AM Thread Starter
coolhandluke's Avatar
I was driving down the highway and my car jumped out of 5th gear. I can keep it in gear if I do not give it too much throttle. Anyone else have an “inexpensive” fix for this?
2006 Mazda 6 S Wagon
5spd
coolhandluke is offline
Old 03-28-2019, 11:22 PM
hurddawg's Avatar
Quoted: 63 Post(s)
I haven't research this on the 6 in particular, but in other vehicles I've had an issue like this has had bad engine mounts. I've read the lower subframe mount on the 6 has a tendency to go bad, which would control/limit the engine from torquing. If it was bad enough it could allow too much movement of the engine and potentially pulling it out of gear. Something you might want to look into before replacing the trans for pop-out/worn fork.
- 1957 Chevrolet Sports Sedan
hurddawg is offline
Old 03-28-2019, 11:41 PM
Quoted: 434 Post(s)
I am with @hurddawg on this one.
Replace all 3 motor mounts. They are all likely worn, by putting only one new mount in, the movement from the other two worn mounts will prematurely destroy the single new mount.
Its not as hard as you may think.
Good luck.
Mozz-D
DrFeelGood is online now
Similar Threads
2006 Mazda 6 Wiring manual ????? Ma6Ral Electrical / HVAC 9 06-29-2017 07:35 PM
2006 Mazda 6 Wagon Power Locks (Electrical) Issue Thunder14 Electrical / HVAC 0 06-25-2013 03:44 PM
wtb: interior fuse box cover, 2006 mazda6 manual mattr Want To Buy 0 01-05-2012 06:12 PM
Aviation Humor explorecaves Lounge 15 09-04-2007 08:21 PM
Mazda NA press release on 6 hatch and wagon PhilH Mazda6 (Atenza) 33 01-03-2004 11:43 PM
