Oil in air intake, and on air filter - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 9 (permalink) Old 03-15-2019, 08:16 PM Thread Starter
Quoted: 12 Post(s)
My 04 wagon baby has just recently started to leak oil onto the air filter, which is certainly a good sign. It's finally decided to reduce the friction of the air, leading to higher performance!
All jokes aside, this seems like it would be my PCV valve stuck open, or closed(hopefully open) right? Or would there be something different I'm missing? Nothing really smokes or anything like that, but I have also noticed it smells EXTREMELY rich on start-up, if that has anything to do with it at all 😕
Thanks.
SlowCarFast is offline
post #2 of 9 (permalink) Old 03-15-2019, 08:29 PM Thread Starter
Quoted: 12 Post(s)
I see that it's coming straight from the Valve cover hose to the intake, leaking down to the filter. I'm even more positive that it's the PCV. But would it be stuck open or closed? As it's been driven a little since I've found out about it. A little worried.
ID:	226822   Click image for larger version
ID:	226824   Click image for larger version
post #3 of 9 (permalink) Old 03-15-2019, 09:54 PM
Quoted: 392 Post(s)
Hey there.
My list for this is:
1. PCV malfunction. Replace the valve and upgrade the hose to the reinforced design. AJTT-13-89Y
2. Worn Piston rings.
Odds are it is either a faulty PCV valve or the PCV hose is collapsed...or both.
DrFeelGood is offline
post #4 of 9 (permalink) Old 03-16-2019, 03:07 PM Thread Starter
Quoted: 12 Post(s)
Originally Posted by DrFeelGood View Post
Hey there.
It's not the Piston rings. Well, maybe. But even if it is, it's not. I refuse to believe 😛
What do you mean by the PCV hose collapsed? The hose that comes right off of it?
Also, is the dealership still a good place to pick up a PCV valve, or are there better options now? I've seen threads from 2015 that talk about it, but I haven't come across any newer ones.
Thanks a lot 🙂
post #5 of 9 (permalink) Old 03-16-2019, 03:42 PM
Quoted: 36 Post(s)
PCV and/or hose are restricted or clogged.
Science behind it: All engines experience blow-by which contaminates the oil and pressurizes the crankcase. PCV valve is supposed to apply a regulated vacuum to the crankcase to evacuate the fumes, and draws in fresh air from a tap on the air intake side.
When the PCV (or hose) are restricted or blocked, the pressure is relieved through the air intake side; along with any oil mist it may contain.
Mad Myche is offline
post #6 of 9 (permalink) Old 03-16-2019, 04:40 PM
Quoted: 392 Post(s)
Thanks a lot 🙂
You can pick all that up at the dealership or online. It just depends on how much you want to pay and how long you want to wait.
Be advised there are two PCV valves and I believe they changed either late 2004 or 2005. There is a long and short version. The hoses that connect them from the intake manifold are also different.
The hose pictured on the left will collapse flat but one on the right with the reinforcement will not collapse.
For part numbers there is a bit more here on this thread.
Both will fit all years, the only consideration is the valve needs to match the hose.
post #7 of 9 (permalink) Old 03-16-2019, 05:52 PM Thread Starter
Quoted: 12 Post(s)
Ohh okay. Thanks a lot! Mine most definitely is the first one. I'll see if I can't pick up the updated hose and PCV. Seems like a good idea to upgrade that.
Thanks again 🙂
post #8 of 9 (permalink) Old 03-16-2019, 11:13 PM
ignis0's Avatar
Quoted: 7 Post(s)
I also noticed a moisture in my air hose when I did my airbox mod today. Is this why my car smells like gas every time I start it and/or turn on the heat? Guess I'll have to do this when I replace my spark plugs and do the egr mod.
My Six: 2004 Mazda 6 3.0L ATX
Vehicles in my Garage
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
ignis0 is online now
post #9 of 9 (permalink) Old 03-17-2019, 06:45 PM Thread Starter
Quoted: 12 Post(s)
My car smells so strong of gas when I start it. I don't think it did when I first did the airbox mod though. I always just assumed mine did because my whole rear interior is stripped 🤷
Similar Threads
2.5G power potential RacingTiger03 2.5L I-4 238 10-20-2016 05:23 AM
How a high flow intake can make power gains on a modern Mazda6 engine solar365 Engine / Drivetrain 85 03-26-2014 10:12 AM
How to change intake filter mazdagirl77 2.3L I-4 10 02-11-2013 09:18 AM
Quick Cold Air Intake Filter question mazdagirl77 2.3L I-4 5 02-10-2013 08:45 PM
CAI intake filter for CPE. arch4life 3.0L V6 2 01-19-2006 03:46 PM
