Oil light on at idle - Page 4 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 4Likes
post #31 of 46 (permalink) Old 02-08-2019, 04:27 PM
tickerguy's Avatar
Quoted: 920 Post(s)
Groaned at 7 Times in 7 Posts
How's blowby? That's another good indicator -- remove the hose from the PVC connection at the valve cover with the engine idling -- if you're basically pumping exhaust into the crankcase (due to trashed valve guides or rings, both of which result in pretty extreme oil consumption too) it'll be pretty obvious
If either of those is that worn then the odds go up (although it's by no means conclusive; you can have trashed valve guides and yet clearances are fine) that you have serious bearing wear too -- which is where the oil pressure problem at idle frequently comes from (the other common causes are a clogged pickup as noted above or a bad pump, frequently the pressure-maintaining valve which can stick open.) If you have a clogged pickup odds are good you also have other problems since sludging is rarely in only one place...
tickerguy is online now
zsElric (02-08-2019)
post #32 of 46 (permalink) Old 02-08-2019, 05:31 PM Thread Starter
zsElric's Avatar
Quoted: 27 Post(s)
Thank you, I will definitely check for these things, luckily I do have another car I can drive. But gonna keep my fingers crossed that it's nothing to serious.
Sent from my SM-G950U using Tapatalk
zsElric is offline
post #33 of 46 (permalink) Old 02-11-2019, 04:00 PM
Quoted: 447 Post(s)
Mine started up again today
Going to add an oil filter sandwich plate and sender to bypass my original sender switch which is stripped in place.
I believe the filter thread size is 22mm x 1.5
Can anyone verify that? Pretty please?
EDIT: Thanks for the confirmation @bluedevil6 regarding the filter thread and also the PM.
bluedevil6 likes this.
Mozz-D
DrFeelGood is offline
post #34 of 46 (permalink) Old 02-12-2019, 04:51 PM Thread Starter
zsElric's Avatar
Quoted: 27 Post(s)
https://youtu.be/tPU9xMiqPyg
Yeah that is exactly the same as mine is doing. Unfortunately haven't been able to work on it at all. Been getting a lot of snow and dont have a garage.
zsElric is offline
post #35 of 46 (permalink) Old 02-12-2019, 04:59 PM
waughoo's Avatar
Quoted: 422 Post(s)
Yeah that is exactly the same as mine is doing. Unfortunately haven't been able to work on it at all. Been getting a lot of snow and dont have a garage. <img src="http://forum.mazda6club.com/images/smilies/6.gif" border="0" alt="" title="" class="inlineimg" />
Yes... my 6 is buried from this onslaught of snowmageddon 2019.
ID:	226392   Click image for larger version
Alex
, and
waughoo is offline
post #36 of 46 (permalink) Old 02-12-2019, 05:02 PM Thread Starter
zsElric's Avatar
Quoted: 27 Post(s)
Damn where are you at again? Over by seattle? I'm closer to the cost so I dont have that much but still to much to do anything.
zsElric is offline
post #37 of 46 (permalink) Old 02-12-2019, 05:45 PM
bluedevil6's Avatar
Quoted: 208 Post(s)
.Note to Self: never move to the Pacific Northwest. lol
2007 6 Hatch 3.0 V6 ATX
Places to find me-
bluedevil6 is offline
post #38 of 46 (permalink) Old 02-12-2019, 07:32 PM
waughoo's Avatar
Quoted: 422 Post(s)
I'm up north a bit from Seattle in Edmonds. This is crazy uncharacteristic for our region. The local schools have had two days closed last week, two late starts and one early dismissal and now three days this week closed (they just announced that school is closed for tomorrow)
It is really strangefor it to snow this much and then stay cold enough for it to stick around. I had to put chains on my work van just to get out of the neighborhood and then take them off so I could drive on the freeway!
Alex
, and
waughoo is offline
post #39 of 46 (permalink) Old 02-12-2019, 09:02 PM Thread Starter
zsElric's Avatar
Quoted: 27 Post(s)
Even with it not being normal, still dont move to the pacific northwest. Unless you like rain 9 months out of the year.
zsElric is offline
post #40 of 46 (permalink) Old 02-12-2019, 10:01 PM
Quoted: 447 Post(s)
This is so true. Whatever you do don't move here...there.
Mozz-D
Similar Threads
DPF light on solid shortly after forced regen Kresten_m 2.0-2.2L Diesel 0 06-24-2015 07:00 AM
AT light problem Please Help Mercylor Newbie Section 0 04-16-2013 07:29 PM
Mazda 626 Rough And Unsteady Idle hleonk Lounge 3 03-31-2013 11:47 PM
Idle Surge But car runs Great??? Any IDeas?? jayrx7trbo2 3.0L V6 11 07-27-2011 08:42 AM
Red Light Cameras UCLeadGuitar Lounge 30 06-03-2005 12:40 PM
