Does the 06 3.0L have an IACV? - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 1Likes
post #21 of 38 (permalink) Old 02-10-2019, 01:08 PM Thread Starter
TampaBay6's Avatar
Quoted: 16 Post(s)
I'm on every part site under the sun but would prefer to use Amazon. The part number is either K5T49096 or maybe BP4Y-18-741. The OEM Mazda sites have horrible schematic diagrams.
2006 Mazda6, 3.0L v6, six speed auto (all stock, and loving it.)
TampaBay6 is offline
post #22 of 38 (permalink) Old 02-10-2019, 02:12 PM
waughoo's Avatar
Quoted: 349 Post(s)
I had a little trouble finding mine but I believe the thread I posted in for the codes I was having had a link to a replacement. Hold tight...
Alex
, and
waughoo is offline
post #23 of 38 (permalink) Old 02-10-2019, 02:15 PM Thread Starter
TampaBay6's Avatar
Quoted: 16 Post(s)
I just got home from a trip to AutoZone. They have no idea what part I need. I took the guy out to the car, opened the hood, and pointed to it. They have nothing on their computer system. He was like "sorry man, maybe you should check on-line."
post #24 of 38 (permalink) Old 02-10-2019, 02:15 PM
waughoo's Avatar
Quoted: 349 Post(s)
Okay... go to page 4 of this thread...
https://www.mazda6club.com/#/topics/284361
The Doc posted a couple links with part numbers. If memory serves one of those was the correct replacement for the Boost Solenoid sensor.
Alex
, and
waughoo is offline
post #25 of 38 (permalink) Old 02-10-2019, 02:36 PM
Quoted: 367 Post(s)
@TampaBay6 The above link didn't work for me but since I am at a terminal I can easily find, cut, and paste the numbers from @waughoo post.
Baro sensor: KL47, E1T10372, A 4526
EGR Boost sensor solenoid: K5T49096, BP4Y, 4427
Modifications:
.MSP brakes &
slotted rotors
DrFeelGood is offline
post #26 of 38 (permalink) Old 02-10-2019, 03:26 PM
waughoo's Avatar
Quoted: 349 Post(s)
@DrFeelGood Did you edit your post that had the links to the car parts dot com page? One of those links was correct. It's actually the part the OP was looking for. I went back to try and find it again just now but it wasn't there.
Alex
, and
waughoo is offline
post #27 of 38 (permalink) Old 02-10-2019, 04:30 PM
Quoted: 367 Post(s)
Yes. I did not want to mislead someone and since I couldn't tell which was correct (and you posted updated links) I decided to clear the incorrect data.
Modifications:
.MSP brakes &
slotted rotors
post #28 of 38 (permalink) Old 02-10-2019, 05:11 PM
waughoo's Avatar
Quoted: 349 Post(s)
Good to know I'm not just seeing things @DrFeelGood . I got confused when I looked back and said, "the link was there when I posted the thread about 10 minutes ago. Where is it now?" 🙂
Alex
, and
waughoo is offline
post #29 of 38 (permalink) Old 02-11-2019, 09:40 AM Thread Starter
TampaBay6's Avatar
Quoted: 16 Post(s)
I also followed the link and it took me to the Mazda6Club home page.
So the correct part numbers are these three EGR Boost sensor solenoid: K5T49096, BP4Y, 4427 ?
What part is the 4427?
post #30 of 38 (permalink) Old 02-11-2019, 11:52 AM
Quoted: 24 Post(s)
Originally Posted by TampaBay6 View Post
I checked my codes and P0455 is gone.
Now I'm working with P2144. "EGR boost sensor solenoid valve circuit low input." What does that all really mean?
Anyone know how to test that solenoid? And does anyone know the part number?
EGR BOOST SENSOR SOLENOID VALVE INSPECTION [AJ]
Airflow Inspection NOTE:
  • Perform the following procedure only when directed.
1. Disconnect the negative battery cable.
2. Remove the EGR boost sensor solenoid valve.
3. Inspect airflow between each port under the following conditions.
  • If not as specified, replace the EGR boost sensor solenoid valve.
  • If as specified, carry out the “Circuit Open/Short Inspection”.
Click to Enlarge
Click to Enlarge
Circuit Open/Short Inspection 1. Disconnect the PCM connector. (See PCM REMOVAL/INSTALLATION [AJ].)
2. Inspect the following wiring harnesses for open or short circuit (Continuity check).
Click to Enlarge
Click to Enlarge
  • Open circuit
  • If there is no continuity, there is an open circuit. Repair or replace the wiring harness.
    • EGR boost sensor solenoid valve terminal B and PCM terminal 1AX
    • EGR boost sensor solenoid valve terminal A and main relay terminal C
  • Short circuit
  • If there is continuity, there is a short circuit. Repair or replace the wiring harness.
    • EGR boost sensor solenoid valve terminal B and body GND
    • EGR boost sensor solenoid valve terminal A and power supply
Raksj04 is offline
Similar Threads
3.0L V6 One Stop Shop... fullyarmed101 3.0L V6 33 10-03-2016 09:15 PM
3.0L V6 Large Diameter Throttle Body R & D!!!! The Great NY 3.0L V6 90 02-12-2011 11:45 PM
Steeda Throttle Body Spacer for 3.0L V6 slopo Engine & Transmission 5 07-29-2010 03:21 AM
Jaguar 3.0L vs Mazda 3.0L twdavis Engine / Drivetrain 21 03-16-2004 05:58 PM
more Products for the 3.0L (more power!!!) SPAWN Engine / Drivetrain 40 12-16-2003 11:45 PM
