2005 Mazda 6 wagon - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 6Likes
post #1 of 22 (permalink) Old 01-26-2019, 02:14 PM Thread Starter
Jael Ryan's Avatar
Quoted: 14 Post(s)
2005 Mazda 6 wagon
Hi I'm new in this forum. My car is throwing a lot of codes involving the EGR and the system Bank. I have a po303 po401 p2179 p2177 and many more does anyone know how to diagnose this or fix it?
Regards,
Jael Ryan
Jael Ryan is offline
post #2 of 22 (permalink) Old 01-27-2019, 05:13 PM
bluedevil6's Avatar
Quoted: 202 Post(s)
Here are some snaps from my FSM hopefully these will help you. that P0303 is a misfire code and you are going to want to take care of that immediately so it doesn't destroy your pre-cats. I also noticed that your other codes could be caused by a misfire, my guess is that you need one or more new ignition coils they regularly go bad on these.
Name:	misfire code 303.jpg
ID:	226148   Click image for larger version
ID:	226150   Click image for larger version
ID:	226152   Click image for larger version
ID:	226154   Click image for larger version
ID:	226158   Click image for larger version
ID:	226160   Click image for larger version
ID:	226162   Click image for larger version
ID:	226164   Click image for larger version
Kalalicious likes this.
2007 6 Hatch 3.0 V6 ATX
Places to find me-
bluedevil6 is online now
post #3 of 22 (permalink) Old 01-27-2019, 05:14 PM
bluedevil6's Avatar
Quoted: 202 Post(s)
here are the other pages, it would only let me attach so many at once lol
ID:	226168   Click image for larger version
Places to find me-
post #4 of 22 (permalink) Old 01-27-2019, 07:35 PM
waughoo's Avatar
Quoted: 422 Post(s)
@Jael Ryan , as @bluedevil6 says, solve those misfires pronto! I'm not sure how many miles you have on your long top, but the coils are a bit of a service item on these cars. It is unfortunate, but it seems that many people seem to start having issues at 100k miles. I would strongly suggest a full replacement of the coils and likely a set of plugs. The issue is that getting to them can be a bit of a problem and delaying the repair can cause significant expense and possible engine failure. I don't want to scare you there, but pre cat failure on these duratec v6 engines is well documented. I'd start with the misfire fix first. One thing I'd add too is that the harness clips that go into the coils can sometimes lose their pliability and they will break off the little clip that secures them into the coil. I had this problem and ended up using a small zip tie to make sure it would stay in place. It is not my favorite solution, but the only other resolution is to replace the plug at that given coil. I had bought the parts to do so but decided it was going to be so much work as there isn't much room to work on the harness at the coil location. I still have the clips but my zip tie solution is still working fine for the moment.
Alex
, and
waughoo is offline
post #5 of 22 (permalink) Old 01-27-2019, 07:43 PM
Quoted: 419 Post(s)
Welcome to the form, we love our wagons (although I could be biased)
The P0303 is the killer, you gotta get this fixed. Usually I is remedies by new plugs and coils but moving cylinder 3 to another location and waiting for the code retuen would be a way to verify. (It is happened so many times on this forum that if you haven't replaced those items I would just do all 6)
The search bar in the upper right will take you straight to all those codes. There you can read what other people did to fix similar scenarios.
If I had to guess I would say either the EGR is clogged or the EGR purge valve solenoid is not working.
For the Lean codes make sure you do net have an intake air leak. The accordion hose running from the air cleaner is notorious.
OEM parts
Mazda AJTT-18-110 - Spark Plugs x6 (these will be Motorcraft AGSF 22FSCM)
DENSO 673 6005 - Ignition Coils x6
DrFeelGood is online now
post #6 of 22 (permalink) Old 01-29-2019, 02:44 PM Thread Starter
Jael Ryan's Avatar
Quoted: 14 Post(s)
Really appreciate this man&#x270a;
bluedevil6 likes this.
Regards,
Jael Ryan
post #7 of 22 (permalink) Old 01-29-2019, 02:46 PM Thread Starter
Jael Ryan's Avatar
Quoted: 14 Post(s)
I will solve this pronto. My dad's helping me take it to a dealer to have it checked. The car has about 109500 miles.
Regards,
Jael Ryan
post #8 of 22 (permalink) Old 01-29-2019, 02:50 PM Thread Starter
Jael Ryan's Avatar
Quoted: 14 Post(s)
OEM parts
I checked the accordion hose and found no leak thus far with my miniscule car know how. My dad suggested taking it to Mazda for diagnostics and see what it'll need.
Crossing fingers it won't take all my tax money
Regards,
Jael Ryan
post #9 of 22 (permalink) Old 01-29-2019, 02:52 PM Thread Starter
Jael Ryan's Avatar
Quoted: 14 Post(s)
OEM parts
PS......are aftermarket iridium plugs worth the buy?
Regards,
Jael Ryan
post #10 of 22 (permalink) Old 01-29-2019, 02:56 PM
waughoo's Avatar
Quoted: 422 Post(s)
Taking it into the dealer for a diagnostic is often a great solution. They have more vehicle specific knowledge than an independent and can often get to the crux of the problem with less labor. Regardless, I'd make sure you solve that misfire quickly. I'd replace all the coils to avoid future misfires as others fail. Keep us posted on how it goes.
Alex
, and
waughoo is offline
