Timing Cover removal in vehicle - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 4 (permalink) Old 12-05-2018, 07:26 PM Thread Starter
Quoted: 51 Post(s)
Does anyone have any tips or a rough guide on what has to be removed to take the timing cover off with the motor still in the car?
I’m going to be replacing the lifters and have to remove timing cover along with valve covers and cams. I have done valve covers just not the timing cover.
The alldata write up is for lifting the whole motor above the engine bay.
audiofreak19 is offline
post #2 of 4 (permalink) Old 12-05-2018, 10:27 PM
Quoted: 363 Post(s)
Iím going to be replacing the lifters and have to remove timing cover along with valve covers and cams. I have done valve covers just not the timing cover.
It appears to be a fairly involved job. Mine is leaking and getting worse every season (only 2 here in PNW, wet and dry)
Here are links to video that shows the attack. Good Luck.
https://youtu.be/CrQVPfniviQ
https://youtu.be/84-bPOw0h7o
https://youtu.be/3HlZglKLlAc
Modifications:
.MSP brakes &
slotted rotors
DrFeelGood is offline
post #3 of 4 (permalink) Old 02-12-2019, 01:27 PM
Did you guys do this job yet? Thinking of trying to tackle it soon and was curious if you had any tips, or things you ran into that may be helpful to know.
cschmidt89 is offline
post #4 of 4 (permalink) Old 02-12-2019, 06:05 PM
waughoo's Avatar
Quoted: 347 Post(s)
I've watched the videos above and they are pretty good at talking you through the process. It is a big job for sure but doable. I'd prefer to do it inside since the engine will be open for a bit.
Alex
, and
waughoo is online now
