2006 mazda 6 3.0 purge valve location - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 9 (permalink) Old 09-13-2016, 09:38 PM Thread Starter
hey guys, i'm trying to locate the purge valve on my mazda. i've read everything from "it's to the left of the engine on the firewall" to "it's right next to the battery, can't miss it" but i'm still not finding it...... does anyone have any insight?
Thanks in advance!
psykobillys is offline
post #2 of 9 (permalink) Old 09-14-2016, 08:53 AM
b1lk1's Avatar
Quoted: 263 Post(s)
Groans: 19
Multiple purge valves under the hood for different systems.
EVAP purge valve is next to the throttle body on a little bracket attached to the air intake hose.
b1lk1 is offline
post #3 of 9 (permalink) Old 09-15-2016, 07:01 PM Thread Starter
what about the fuel canister vapor purge valve?...
post #4 of 9 (permalink) Old 09-15-2016, 09:55 PM
b1lk1's Avatar
Quoted: 263 Post(s)
Groans: 19
That's the one next to the throttle body.
b1lk1 is offline
post #5 of 9 (permalink) Old 09-16-2016, 12:55 PM Thread Starter
? man... I just don't see it. ?
post #6 of 9 (permalink) Old 09-16-2016, 07:49 PM
b1lk1's Avatar
Quoted: 263 Post(s)
Groans: 19
Here you go.
Name:	Mazda 6 emissions valves.jpg
b1lk1 is offline
post #7 of 9 (permalink) Old 09-17-2016, 12:03 PM Thread Starter
Thanks but I'm still not seeing it... Is it visible in any of these pics?
ID:	193001   Click image for larger version
ID:	193009   Click image for larger version
ID:	193017   Click image for larger version
post #8 of 9 (permalink) Old 09-17-2016, 12:31 PM
b1lk1's Avatar
Quoted: 263 Post(s)
Groans: 19
I don't think I can see it where it is supposed to be, but your pictures are also on the small side. If looking at the engine while standing in front of the car, the purge valve is supposed to be attached to the rubber intake hose right up next to the throttle body. There are 2 lines that run to it and an electrical plug. If it is indeed missing you'll need to find the lines and electrical plug when you replace the valve/solenoid. Look down in that triangle just to the left of the throttle body.
b1lk1 is offline
post #9 of 9 (permalink) Old 09-07-2018, 03:40 PM
TampaBay6's Avatar
Same issue. I don't see the evap. canister purge solenoid anywhere. It isn't connected to the air intake hose. Maybe someone could help if the could point out the evap. canister. I have a 2006 3.0L.
2006 Mazda6, 3.0L v6, six speed auto (all stock, and loving it.)
TampaBay6 is offline
