Can't load CDs - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 4 (permalink) Old 10-22-2017, 05:28 PM Thread Starter
Can't load CDs
I have a 2009 Mazda6 with Bose and Nav. I am currently have 2 issues that I could use some help with. I just purchased a replacement Nav disc and loaded it in addition to attempting to load a few CDs but the screen gets stuck in the open position and the cd changer won't take the CDs. Any ideas? Thanks to all in advance. BTW I am still having the same issue from my prior post about blanking out all prior bluetooth info from the former owner that keeps retaining their voice and phonebook.
katnkanga is offline
post #2 of 4 (permalink) Old 10-23-2017, 12:55 PM
Mz6GreyGhost's Avatar
Quoted: 784 Post(s)
Have you tried disconnecting the battery, waiting 15 minutes, then reconnecting it? Usually a "hard" reset fixes the odd problem or two...
Mz6GreyGhost is offline
post #3 of 4 (permalink) Old 10-23-2017, 02:49 PM Thread Starter
I currently pulled the 30 amp radio fuse and then disconnected the negative terminal... in that order. The car has been sitting that way for about 4 hours now. I thought I read somewhere that this helped someone but it took being disconnected overnight for it to work. Do you think disconnecting both terminals and touching them together to pull all remaining juice? If I do that should I put the fuse back in first? Thanks
post #4 of 4 (permalink) Old 10-24-2017, 10:38 AM
Quoted: 784 Post(s)
I'd try that method if what you did yesterday didn't work.
