Wrong engine oil grade used by dealer - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 5Likes
post #1 of 53 (permalink) Old 10-27-2018, 09:58 PM Thread Starter
Quoted: 4 Post(s)
I am an owner for 2018 Mazda 6 Grand Touring Reserve, 2.5 turbo for six months. I went to the dealer for an oil change today. Though I specifically asked the dealer to use 5W30 which is required for the turbo engine, they still used 0W20 which is only good for the NA engine and claimed it'd run fine for the turbo engine.
I don't buy it as 0W20 is too thin and don't know why they don't stick to the manufacturers recommendation. I've filed a complaint to Mazda USA and will see how things fall out. Need some opinion on whether I should drive the car next couple of days. I fear oil consumption would come up.
leecod is offline
post #2 of 53 (permalink) Old 10-27-2018, 11:10 PM
MazdaMetalhead's Avatar
Quoted: 153 Post(s)
It's not going to hurt your engine in the short term. Did the dealer flat out refuse to drain it and put in the correct oil?
Manual transmissions, wagons, and heavy metal are awesome. Zoom-Zoom \m/
2004 Mazda 6s Wagon - 3.0L V6 | 5MT | Steel Gray Metallic |
Mods: 2015 OEM 17" 6 rims | NGK Iridium IX plugs | Matte black painted OEM wheels (winters) | Red painted calipers | Light black "smoked" headlights | R1 Concepts eLine rear rotors and pads | Rear V6 emblem added
Other Mazdas owned: 2015 Mazda 5 Sport ATX (current), 2010 Mazda 6 ATX (traded), 1997 Protege MTX (sold)
MazdaMetalhead is offline
post #3 of 53 (permalink) Old 10-28-2018, 02:45 AM
zPacKRat's Avatar
Quoted: 23 Post(s)
Groans: 11
If the manual for the turbo states 5w30 then I would insist that they use the correct oil, even if that means they drain/fill what they just did.
Mr. Orange:
What happens if the manager won't give you the (correct oil) diamonds?
Mr. White:
When you're dealing with a store like this, they're insured up the ass. They're not supposed to give you any resistance whatsoever. If you get a customer, or an employee, who thinks he's Charles Bronson, take the butt of your (keys) gun and smash their nose in. Everybody jumps. He falls down screaming, blood squirts out of his nose, nobody says f***ing shit after that. You might get some bitch talk shit to you, but give her a look like you're gonna smash her in the face next, watch her shut the f*** up. Now if it's a manager, that's a different story. Managers know better than to f*** around, so if you get one that's giving you static, he probably thinks he's a real cowboy, so you gotta break that son of a bitch in two. If you wanna know something and he won't tell you, cut off one of his fingers. The little one. Then tell him his thumb's next. After that he'll tell you if he wears ladies underwear. I'm hungry. Let's get a taco.
2006 Mazda 6s Auto with 145,000 Miles (traded for 2015 Touring)
2015 Mazda 6 Touring w/6Spd Manual (having an ex wife allows for having a manual again
)(traded for 2017 Touring)
2017 Mazda 6 Touring w/Auto (done rowing gears and the skyactive auto has proven to be far more reliable than the one in my 2006)
zPacKRat is offline
post #4 of 53 (permalink) Old 10-28-2018, 12:25 PM Thread Starter
Quoted: 4 Post(s)
The service advisor said they don't have 5W30 after the oil change when I found out they used the wrong grade. Will contact them on Monday when their service manager is in.
leecod is offline
post #5 of 53 (permalink) Old 10-28-2018, 01:54 PM
Mz6GreyGhost's Avatar
Quoted: 831 Post(s)
Groaned at 6 Times in 3 Posts
It's safe to drive, but I'd definitely follow up with the dealer and Mazda.
Mz6GreyGhost is offline
post #6 of 53 (permalink) Old 10-28-2018, 03:19 PM
Quoted: 12 Post(s)
Question how did you or how does one know what oil grade a dealership uses?
(Other than ask)
tempdownload is offline
post #7 of 53 (permalink) Old 10-28-2018, 04:12 PM Thread Starter
Quoted: 4 Post(s)
(Other than ask)
It is clearly stated in the service invoice. They used 0W20 Havoline Synthetic.
leecod is offline
post #8 of 53 (permalink) Old 10-29-2018, 08:56 AM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2872 Post(s)
What the others said - You'll be fine but absolutely don't let it happen again and let them know they screwed up.
(Another reason I do my own).....
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
post #9 of 53 (permalink) Old 10-29-2018, 10:06 AM
tickerguy's Avatar
Quoted: 905 Post(s)
Groaned at 7 Times in 7 Posts
I would NOT leave that oil in there. It won't hurt the engine (at all) but it MAY cause turbo trouble down the road, and I would also pay close attention to oil level, since the thinner viscosity is likely to result in materially higher consumption through turbo bypass (which ultimately goes down the intake and gets burned up.)
And use the correct (full-synthetic) 5w30.
tickerguy is offline
post #10 of 53 (permalink) Old 10-29-2018, 11:25 AM Thread Starter
Quoted: 4 Post(s)
Contacted dealer again this morning. They still wouldn't admit they screwed up and still claimed 0W20 is perfect in Florida area (where I live).
leecod is offline
