Oil smell after warmed up - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 7 (permalink) Old 03-11-2019, 10:26 PM Thread Starter
red_johnny's Avatar
So after about 15 mins of driving I notice an oil smell in the cabin. I did add oil a few weeks ago but this smell was before that. There are no leaks that I see or spots on the ground. What could be the issue? I thought possibly an exhaust leak at the header but that is unlikely as I would smell exhaust. I am thinking maybe a vacuum tube leaking some burnt oil? Its going to drive me nuts if I cant figure out how to fix it. Anyone have some ideas?
red_johnny is offline
post #2 of 7 (permalink) Old 03-11-2019, 10:28 PM Thread Starter
red_johnny's Avatar
Forgot to add email notification
post #3 of 7 (permalink) Old 03-12-2019, 01:37 AM
waughoo's Avatar
Quoted: 422 Post(s)
If you have a V6, they are a bit prone to leaking from the front cover and the valve cover gaskets and it drips down on the exhaust causing the smell. I did my valve cover gaskets and that made a rather large improvement, but didn't completely cure it.
Alex
, and
waughoo is online now
post #4 of 7 (permalink) Old 03-12-2019, 07:56 AM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2872 Post(s)
He posted it in the 2.3L section so this might not be the case. Sorry OP, I know very little about the 2.3L but hopefully someone else can help you out!
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
post #5 of 7 (permalink) Old 03-12-2019, 10:11 AM Thread Starter
red_johnny's Avatar
That actually makes sense. I will try to check it out this weekend and pull over the plastic engine cover to see if this may be the case.
post #6 of 7 (permalink) Old 03-12-2019, 10:50 AM
waughoo's Avatar
Quoted: 422 Post(s)
I'm almost always on my mobile and so I dont get to see signatures. I didnt even think to look at the forum section for that info.
Regardless, I would look at your valve cover seal. In a 4 cyl car, the leak at the valve cover can often drip down or weep down the head and land on the exhaust manifold causing that same oil burn smell.
Alex
, and
post #7 of 7 (permalink) Old 03-12-2019, 10:56 AM Thread Starter
red_johnny's Avatar
Thanks, I will check it out
Similar Threads
Weird engine heat smell??? ms6fanatic Speed6 Engine/Drivetrain 20 12-23-2011 12:35 PM
Horrible Horrible smell in my car HedsIc Mazda6 (Atenza) 34 01-21-2011 02:08 PM
Oooh that Smell! Can't you smell that smell? priceprince Mazdaspeed6 36 03-16-2010 08:10 PM
burning smell and misfire beyernk 3.0L V6 1 10-24-2008 06:31 PM
Rotten egg like smell. HedsIc 2.3L I-4 12 12-05-2005 02:47 PM
