-   2.3L I-4 (https://forum.mazda6club.com/228-2-3l-i-4/)
-   -   Oil smell after warmed up (https://forum.mazda6club.com/2-3l-i-4/439188-oil-smell-after-warmed-up.html)
red_johnny 03-11-2019 10:26 PM
So after about 15 mins of driving I notice an oil smell in the cabin. I did add oil a few weeks ago but this smell was before that. There are no leaks that I see or spots on the ground. What could be the issue? I thought possibly an exhaust leak at the header but that is unlikely as I would smell exhaust. I am thinking maybe a vacuum tube leaking some burnt oil? Its going to drive me nuts if I cant figure out how to fix it. Anyone have some ideas?
red_johnny 03-11-2019 10:28 PM
Forgot to add email notification
waughoo 03-12-2019 01:37 AM
If you have a V6, they are a bit prone to leaking from the front cover and the valve cover gaskets and it drips down on the exhaust causing the smell. I did my valve cover gaskets and that made a rather large improvement, but didn't completely cure it.
Byakuya 03-12-2019 07:56 AM
He posted it in the 2.3L section so this might not be the case. Sorry OP, I know very little about the 2.3L but hopefully someone else can help you out!
red_johnny 03-12-2019 10:11 AM
That actually makes sense. I will try to check it out this weekend and pull over the plastic engine cover to see if this may be the case.
waughoo 03-12-2019 10:50 AM
I'm almost always on my mobile and so I dont get to see signatures. I didnt even think to look at the forum section for that info.
Regardless, I would look at your valve cover seal. In a 4 cyl car, the leak at the valve cover can often drip down or weep down the head and land on the exhaust manifold causing that same oil burn smell.
red_johnny 03-12-2019 10:56 AM
Thanks, I will check it out
